Having some trouble with capture recently.
Here is the signal chain:
PAL VHS>VCR > Scart > 3 Phono (AL, AR, V) > Pinnacle Firewire MovieBox > Firewire cable > PC (Pinnacle Studio to capture)
And here is the result. You see a fine network of "black lines" over the video, almost like black lace. I am not sure what this is or what is causing it, since when the VHS tape is played into a TV, it looks normal.
edit: nevermind ... your description is not what I see in those images.
Strange. Electrical interference or a bad connection can
cause banding like that but I have never seen it so
fine and uniform. I take it that you see this on preview as well as capture? -
Yes, it is also seen on preview, connections/cables are clean and tight. It is grainier than organic whole wheat bread. It was taped directly from TV.
Still puzzled. -
No, by bad connection I meant a dry joint leaking
static in the VCR. It looks ok on a normal TV but
will show up on equipment like
projectors or capture cards which require a clean
signal.
Artifact in U-matic (3/4") capture
By JVRaines in forum Capturing and VCRReplies: 53Last Post: 21st Aug 2012, 09:50 -
Poor Video Image from PAL VHS Capture
By ww12345 in forum Newbie / General discussionsReplies: 4Last Post: 18th Sep 2011, 12:57 -
VHS tape artifact
By dumham in forum Capturing and VCRReplies: 6Last Post: 23rd Aug 2009, 03:27 -
VHS capture jumping between PAL and ME SECAM...help
By pijetro in forum Capturing and VCRReplies: 2Last Post: 21st Feb 2009, 18:55 -
Ghosting on PAL VHS CApture
By tumaz in forum RestorationReplies: 30Last Post: 4th Oct 2007, 15:59
