Hey,
I recently bought a dv camera, and I'd like to transfer the video to my PC. Unfortunately, I don't have a firewire port. Is there any cable that goes from like FireWire to USB or something?
Thanks,
Patrick
No, you will need to buy a firewire card. They go for around 20.00 online. And welcome to the Forums. All the information you will ever need is here. A good beginning is the Guides section to the left.
http://www.newegg.com/app/ViewProductDesc.asp?description=15-104-218&depa=0 -
thanks for replying so quickly
i thought i might need a card, but i dont know if i have room for another card...are there any like interfaces i could buy? -
Do you have a usb2 card in one of the pci slots? If so, you can remove it and replace it with a combo firefire and usb2 card. Or if you are using an audio card, you can replace it with a Soundblaster Audigy 2 which includes a firewire port as well.
Firewire device to computer with no Firewire
By dbuser2 in forum ComputerReplies: 11Last Post: 24th Sep 2010, 20:32 -
Firewire Help
By danman46 in forum Newbie / General discussionsReplies: 1Last Post: 15th Jun 2010, 20:28 -
Motherboard Firewire versus Add-in Card Firewire
By SCDVD in forum Newbie / General discussionsReplies: 7Last Post: 19th Jun 2008, 11:19 -
Firewire Help
By Metalchris in forum Newbie / General discussionsReplies: 1Last Post: 15th Jun 2008, 22:12 -
Firewire
By m baqar in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 21st Apr 2008, 02:35
