I created a SVCD from a DVD Rip, which plays on my computer, but not in my DVD play. I have changed media type in case that was it, but not change to the results. I had to delete the original, so I'm hoping I can fix the actual files on the cd. Thanks in advance.
surferr
here are the question i have to ask you does your DVD player support SVCD and CDRs.....those might be the problem...maybe your player doesnt support CDRs check the list on the left if your DVD player supports CDRs
ok...a little more information. I have several SVCDs and VCDs and they all work fine, so that is not the problem.
I am new to this but I believe DVD, SVCD, and VCD is only a kind of format. Pinoy2201 is asking if your player supports CD-R / CD-RW which are the disc itself. ie. If your player supports VCD but not CD-R / CD-RW, then you could only play the geniune VCD (manufacturer product) and not the home made VCD.
You could check your player's manual or (to the left) you could go to:
http://www.vcdhelp.com/dvdplayers.php?DVDname=&svcd=1&Submit2=Search&Search=Search&viewall=0&order=0
to see your players compatibility. Jordan
MKV file audio out of sync on my computer, inferior computer plays perfect
By dave in or in forum Newbie / General discussionsReplies: 7Last Post: 5th Aug 2011, 21:56 -
DVD plays on Computer but not built in TV DVD player
By crawlfish in forum Newbie / General discussionsReplies: 5Last Post: 17th May 2008, 07:35 -
dvd plays on stand-aone player & TV, but not on computer
By ibzomie in forum Newbie / General discussionsReplies: 1Last Post: 19th Jan 2008, 15:18 -
Foreign DVD plays on computer but not on DVD player
By johnharlin in forum Newbie / General discussionsReplies: 3Last Post: 3rd Dec 2007, 22:28 -
DVD plays on Sony DVD Player but cannot be read by Computer
By jeneralzod in forum DVD & Blu-ray WritersReplies: 3Last Post: 28th Jun 2007, 21:35
