NEC 3500a
Nero OEM 6.3
To back a a DVD I use DVD Decrypter, then DVDShrink. Nero is unable to create a DVD from the ISO that DVDShrink creates, so I have been using Decryptor for the burning. The nero burns data DVD's just fine.
Is the Nero 6.3 the problem?
Stick with DVD Decrypter for DVD Video burning.
You can use NERO if you are creating a CD disc of any sort or a DVD data disc.
- John "FulciLives" Coleman
P.S.
You can also use the classic version of ImgTools to create an ISO IMAGE FILE from a VIDEO_TS folder of DVD files."The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
You are selecting the wrong format.
You need to select burn disc image. -
That's what I wanted to hear
I have been using it in the automatic mode - insert a blank DVD+R before using the DVD Shrink. Thanks!
Originally Posted by redwudz
Noobish Nero DVD Burning problem (no space available for recording process)
By windowlicker in forum Authoring (DVD)Replies: 7Last Post: 22nd Dec 2014, 11:24 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
ISO to DVD burning?
By sufcdan in forum MacReplies: 8Last Post: 22nd Feb 2008, 13:42 -
Sound Problem Burning DVD with Nero 7 and TMPGEnc
By brandonc in forum Authoring (DVD)Replies: 4Last Post: 28th Nov 2007, 19:40 -
Iso Burning problem.
By whendreamsweep in forum Newbie / General discussionsReplies: 5Last Post: 29th Aug 2007, 10:24
