    Jan 2003
    Is Prodisc really certified by Pioneer? And if so, do they have a good compatibilty rating? I ask cause I bought some TY and they worked great for me but would not read on my fathers Toshiba SD-1700 stand alone. So far the only media that works with his stand alone is Ritek. But I don't want to buy Riteks after hearing they are on the way down.....
    Yes. It really is. But for the 4x discs, and it's old.
    And not like it means much anyway.
    Jan 2004
    Queens
    I'm interested too. I see Prodiscs are a bit cheaper, but was afraid to buy any. I've been using TY only.
    I've used thousands of PRODISC media.
    Codes: MCC01RG20, MCC02RG20, PRODISCS03, PRODISCF01
    No complaints here. Great discs, all of them.
    May 2003
    canada
    prodiscs03 = 200
    prodiscf01 = 300
    Zero coasters with the nec2500a.
    Great discs.
    Odd the ty's won't play in your fathers toshiba.
    Best of luck
    Kiki
