is there an easy and fast way to rip a dvd to half d1 size. i want to keep the subtitles, just resize the movie.
You need to re-encode and there's nothing quick and easy about that.
I'm not sure about how to keep the subs either."Art is making something out of nothing and selling it." - Frank Zappa -
Try dvd Rebuilder. There is option to "resize to 1/2 d1" in options> avs options. You can use the free internal encoder or for better quality use cce basic about $60.
There's lots of advice/guides on Doom9.org site. Rb is a bit tricky to set up but once it's working it's very easy to use. Try different versions of the decoder MPEG2dec3.dll until you find one that works, put a copy in windows system 32 folder and avisynth plugins folder. This is what solved my no output problem. Try this link;
http://forum.doom9.org/forumdisplay.php?s=2cd3d37da051722e4acb230f1169ab01&forumid=75 -
Originally Posted by anzimikePull! Bang! Darn!
How to select ideal video resolution in AutoGK while ripping?
By vain in forum Newbie / General discussionsReplies: 2Last Post: 5th Nov 2009, 06:36 -
Gotsent Sound Problem! 1st Half 2-Channel 2nd Half 5.1?!?
By Jerec in forum Video ConversionReplies: 1Last Post: 7th Aug 2008, 13:16 -
Half D1 resolution problem
By sebrame in forum Authoring (DVD)Replies: 9Last Post: 30th Jul 2008, 09:18 -
How Do I Split screen Half Rolling Credits-Half Video in Vegas
By Ray & Paula in forum EditingReplies: 1Last Post: 7th Apr 2008, 08:35 -
320x240 avi's to Half-D1 Resolution
By louv68 in forum Video ConversionReplies: 10Last Post: 15th Aug 2007, 08:12
