Would you purchase a new mobo for a pent 3 933ghz chip or get a new pent 4 chip and mobo? The old pent 3 mobo died last month so I ended up building a new pc for my folks. I already have a extra antec case with a 350 power supply, dvdrom, hard drive, & nic. Newegg.com only has 2 pent 3 mobo's to chose from.
Is it worth keeping the pent 933 ghz chip? I'd appreciate any comments. Thanks in advance!![]()
If you have a 933GHz CPU, you should sell it and retire
Seriously, I wouldn't bother with a 933 MHz P3 by buying a MB for it. Get a 2-3 GHz P4 ...they're relatively cheap and you can sometimes get a deal on the CPU/MB combo.
Ram recommendation for amd cpu & biostar mobo combo?
By Stealth3si in forum ComputerReplies: 27Last Post: 11th Feb 2012, 13:05 -
Gigabyte Mobo, Input/opinions needed... & a Q on ram for new build.
By Noahtuck in forum ComputerReplies: 12Last Post: 28th Aug 2011, 08:30 -
Upgrade Celeron 2.6 socket 478 & mobo
By kenmo in forum ComputerReplies: 2Last Post: 6th Jul 2010, 22:29 -
Chip Resetter - Will it reset "auto" 3rd party CIS Chip?
By RBYoshioka in forum MediaReplies: 10Last Post: 10th Nov 2009, 17:49 -
Swapped out mobo & cpu...
By kenmo in forum ComputerReplies: 7Last Post: 5th Apr 2009, 02:50
