weird looking thing, Our Price: $259.99
"Product Description
Make DVDs with the push of a button or two. Sony’s new DVDirect DVD Recorder is the easiest way to turn home movies into DVDs. You’ll have a DVD that can be played on most consumer set-top DVD players or your computer’s DVD-ROM drive. Up to 6 hours of home video will fit on standard DVD recordable or rewritable discs, and with new Double Layer DVD discs, up to 12 hours can be recorded on a single disc. DVDirect can even be connected to a computer via Hi-Speed USB for high speed DVD burning and other cool things."
http://www.buy.com/retail/product.asp?sku=10383806&adid=17051&dcaid=17051
I wonder if Lite-On makes the drive in that unit, like it does the other Sony writers
I've heard many bad things about Sony DVD writers. My Sony Vaio desktop even came with a Pioneer 107 writer instead of a Sony, so that tells you something
But it sounds nice and convenient. I'd like to see user reviews though, before I'd ever consider it. -
It is a LITEON.
That Sony product is stupid. Just get a DVD recorder with "iLINK" and you're set. PLUS you have a full DVD recorder. I don't get it.
Sure, +DL, I guess.Want my help? Ask here! (not via PM!)
Don't waste your money get a LiteOn..
Regards,
TipStirBest Regards,
Tipstir
MediaMVP Supporter -
This is the only DVD recorder I know of that appears to be the size of an external burner, but you can record w/o a computer. Even the similar looking HP unit still needs a computer to operate.
This might be a good unit to record DVD in the field.
I might try this unit out for work.
Any comments?I don't have a bad attitude...
Life has a bad attitude!
Best IDE Burner for burning Dual Layer or Single Layer Discs for Duplicator
By Konfusion in forum DVD & Blu-ray WritersReplies: 7Last Post: 18th Nov 2011, 03:16 -
Dual Layer problem. Layer break issue...
By papegoja in forum DVD RippingReplies: 23Last Post: 9th Jun 2010, 22:52 -
Dual layer disc error (2nd layer not burning properly - AVCHD)
By hhhgamewmx7 in forum Authoring (DVD)Replies: 7Last Post: 24th Aug 2008, 09:00 -
dual layer DVD-R in single layer burner?
By snafubaby in forum MediaReplies: 5Last Post: 4th Oct 2007, 13:39 -
Help on Dual Layer DVD
By mn072065 in forum DVD RippingReplies: 9Last Post: 16th May 2007, 09:36
