I was thinking of buying a CD printer.
But then a I saw a sample from someone else - the print quality is really poor.
And the actual print rubs off onto the hand!
Are there any good alternatives?
(I've read poor reviews for the thermal printers.)
How do the professional printing companies do it?
Thanks.
Jam
Well at a guess he was using to much ink...
Not had any issues with ink rubbing off even straight away after printing... Quality is relative. Some look as good as the originals, others can be a bit off. A lot depends on the source meterial and its quality. The less dark solid colours in the background the better they look.
I would guess bought disks are screen printed.Not bothered by small problems...
Spend a night alone with a mosquito -
Canon Pixma Seems much better than Epson (based on comments from others).
If you are in US you must order from UK to get the working DVD tray.
Try T4 Cameras.
Printing to CD/DVD
By folkboat in forum MediaReplies: 25Last Post: 3rd Sep 2009, 00:51 -
cd/dvd printing
By wingfan in forum MediaReplies: 11Last Post: 23rd Jun 2009, 15:52 -
DVD Label Printing Advice Needed
By jday in forum Authoring (VCD/SVCD)Replies: 3Last Post: 14th May 2008, 20:35 -
Looking For Advice. I'm hoping to get some advice about a DVD burner
By wtsinnc in forum DVD & Blu-ray WritersReplies: 5Last Post: 4th Dec 2007, 23:39 -
What printer to get for DVD Printing
By faramith in forum MediaReplies: 29Last Post: 27th Jul 2007, 08:41
