Okay ... I'm transfering my After Effects 6.5 projects from my PC at home to my computer at work (Mac G5 Dual 2.5 gHz, with AE 6.5). Most of the time, when I used MOV from AVID, I have no problem, but sometimes, I use AVI for footage.
So when I have used AE projects on my MAC before, usually re-directing AVI files is no problem, because they load automaticly into the project. Even when I import them, most of the time they import (could be the AVI codec) but they play in Quicktime on my MAC as just files.
I import them or REPLACE FOOTAGE and I get "After Effects error: the file module could not parse the file. (45 - 35) "
I know these can import in After Effects because I have DV Codec AVI's that have imported. All of my AVI's are DV Codec, so why is AE being stuborn?
Help!
Moving to Mac Video forum ...
Another thing, I have a project with my present AVI in it, and when I import the SAME AVI, I get
"After Effects: AEGP Plugin AAF: Error during parsing: Invalid document Structure 5027 - 12"
and
"After Effects: AEGP Plugin AAF: Error occurred while creating project 5027 - 12"
Hmmm ... It's the same file already in the project !
Importing h.264 mp4 files into After Effects bug?
By Flynn in forum Newbie / General discussionsReplies: 5Last Post: 21st Feb 2012, 10:17 -
Looking for After Effects CS3 for PowerPC Mac
By HowardNeedsHelp in forum MacReplies: 0Last Post: 30th Apr 2011, 13:41 -
After Effects to Premiere... importing problems?
By Saibot in forum EditingReplies: 1Last Post: 21st Feb 2009, 23:48 -
Importing VOBs on a Mac
By Reading Bug in forum MacReplies: 18Last Post: 3rd Feb 2009, 16:42 -
Importing with After Effects- no audio?
By ker-plop in forum MacReplies: 2Last Post: 19th Dec 2007, 22:31
