  1. hi
    is there a way of editing the commercials out of a dvd rw through tmpg authoriser, tried a few methods but am I missing some thing?
    many thanks
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    A couple of these might have some information in them.
    If in doubt, Google it.
  3. hi 8)
    I will have a look thanks some thing I forgot to ask when editing the vob file is it o.k to edit the files seperate eg vst.0. 01 and so on or does this affect the dvd when authorised, or do u need to join the vob and edit
    many thanks
  4. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    If you want to do any editing, I think you'd be better off converting back to one big MPEG-2 file and editing that (see this guide for more information).
  5. hi
    thanks for the links but none are quiet what I was looking for.
    many thanks
  6. hi
    Ihave finally found out how to edit a commercial break using tmpg, find the fisrt frame and use the buttons "Cntl+shift+[ to mark in and the same to mark out except use ] at the end right click and delete selected area.
    hope this helps some one in the future 8)
    The word is "author" and "authoring".
    TDA = TMPGEnc DVD Author
    Glad you have fixed your problem.
