i have 4 MPG2 files which are capture from VHS tape,
after capturing, i put those mpg2 files into TMPG author
to convert .vob and ready to burn DVD.....however,
after converted into VOB, i found the audio sound and
the video picture was not match.....the audio sound have a
bit late in the VOB file.....how can i solve it??? please help!
By the way, can any s/w which can burn DVD directly
from mpg2 file format?
Thx!
Results 1 to 11 of 11
There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
I've played MPEG-2 with those Players but never burned to disc with them, how exactly is this done?Originally Posted by daamon
Sorry, bad English.
Check the VOBs with those apps, before burning with something else...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Hong Kong Special Administrative Region?
As daamon said, you should check them before burning The problem may be before the authoring stage. If the sync is out by a set amount throughout the MPEGs, you can adjust it, but you need to find out where it occurred first.
You might tell use what program you used to capture the files, the method you used and how you combined them. Generally it's better to just add the individual files into your authoring program separately than to combine them before authoring to avoid some sync errors. -
Hey daamon,
i have check my MPEGs, that's all ok...
just after converted into VOB, audio sound
delay....~_~
HKSAR = Hong Kong Special Administration Region
nice to meet you my fd! -
hi redwudz,
All Mpgs is alright of the audio, no delay, just problem after converted into VOB...
thx for your advice, i try combined all 4 MPG2 into 1 and convert again by using TMPG author, hope will fine this time. -
Cool. And you too...Originally Posted by Pritt
No ideas on your problem though... Sorry. It's weird that authoring causes synch problems...
Try your discs on another player...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
LOLOriginally Posted by gastorgrab
From an Englishman's point of view, I'd have to agree... Colour and tyre are but some of the examples I could point out...
Carpe diem.
hi gastorgrab,
Source files (MPG2) are alright.....
the VOB only have sound delay problem....
don't know how to solve it...
TMPG DVD Author-old version
By Mållgan in forum Authoring (DVD)Replies: 12Last Post: 7th Mar 2010, 16:46 -
tmpg dvd author - pal ntsc setting?
By jin007 in forum Authoring (DVD)Replies: 4Last Post: 19th Aug 2008, 14:39 -
Does Tmpg Divx Author encode or it only author ?
By BlackShadow90 in forum Authoring (DVD)Replies: 3Last Post: 29th Jul 2008, 03:56 -
About the .srt subtle files and the TMPG DVD Author
By ihmcjacky in forum Authoring (DVD)Replies: 2Last Post: 10th Mar 2008, 10:58 -
tmpg dvd author 1.6 help plz
By nwa in forum Authoring (DVD)Replies: 8Last Post: 6th Jul 2007, 18:59
