Hi I have a steady winxp sp2 sytem with an ati tv wonder ve and running the drivers off sourceforge.I have 1 SATA 160GB hardrive just for capping and 48gb is free.For some reason when I captured about 24gb it stopped capturing and said something to the effect of "no more disks found."It keeps doing this and screwing me up quite a bit.
-Thanks
you'll win in time
There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Thanks but I had it set to 0 and I have tried setting it to 48GB with the correct number of 0s but it still stopped at 24gb.Originally Posted by bunyip
Anybody?
I'll try WinDV when I have to get I guess but I'm quite a big fan of AVI_IO and Virtualdub always drops frames.you'll win in time -
You know thinking about it a bit more, that's an interesting number and message, the AVI_IO doc says one of the features is ..about 24gb it stopped capturing and said something to the effect of "no more disks found"
it sounds like it might be getting caught up in this somehow."spread the avi files over up to 24 hard drives or partitions (Drive C - Z)"
How many capture files are you getting? -
23 files but when I open the first in VirtualDub it always ask me where the non-existent 24th and 25th files are(more depening on how long i leave avi_io on the errore message)
Also I just tried out WinDV and when I select my device it says "Error Can't find DV Output pin"
-Thanksyou'll win in time
Capturing software
By sruddy in forum Capturing and VCRReplies: 2Last Post: 7th Feb 2011, 14:53 -
Capturing Help
By Kyoji24 in forum Capturing and VCRReplies: 4Last Post: 23rd Apr 2010, 07:37 -
What are you capturing?
By ryangarfield in forum Capturing and VCRReplies: 10Last Post: 20th Apr 2010, 15:16 -
Capturing help.
By fuseek in forum Capturing and VCRReplies: 0Last Post: 6th May 2008, 10:49 -
Capturing in HD
By The Sumerian in forum Capturing and VCRReplies: 1Last Post: 7th Jun 2007, 12:40
