hi dudes, i got a "avi" file that i want to put on to dvd.
i seperated the audio and video (mpeg tmpgnc/audio extracted from virtualdub ).
but now all authoring software states that theres multi channels within my wav file, and when i saved out an ac3 file from virtualdub no program recognises it as a valid ac3 file
i think i have to somehow make my wav file into a pcm, im not a techy by any means, can someone please help!
thanks!
Why are you trying to extract the WAV ?
https://www.videohelp.com/play.htm#identify
Please post back a screenshot from GSpot or AVICodec so we can better understand what you have to work with as source.
It sounds to me like you're using virtualdubmod, not virtualdub.
In virtualdub, go to audio > Full Processing, then go to audio > Compression, and make sure it's set to No Compression (PCM) in the left window. Then go to File > Save WAV.
In virtualdubmod, go to streams > stream list, right-click on the audio stream and go to Full Processing. Then click Save WAV.
More info:
http://members.dodo.net.au/~jimmalenko/ExtractAudio.htmIf in doubt, Google it. -
hi jimmalenko
i was just reading a post you responded to earlier, i posted a link with some of your tutorials, there very helpful, thanks.
im following "SAVE AUDIO TO A SEPARATE WAV FILE"
i think it will work if not ill do what you suggest in this post...
thankyou for your help!
and yeah i was/am using virtualdubmod, i thought they where the same thing, im gonna read up on this so i dont make the same mistake.
Looking for a BD Authoring software that dont re-encode MPEG2 Files
By faramith in forum Authoring (Blu-ray)Replies: 11Last Post: 14th Dec 2011, 04:39 -
Need help authoring DVD from VCD mpeg files with dual audio..
By siratfus in forum Authoring (DVD)Replies: 3Last Post: 15th Aug 2010, 04:31 -
TMPGEnc Authoring Works 4, no audio with AVI files
By aln688 in forum Authoring (DVD)Replies: 5Last Post: 12th Jul 2010, 16:02 -
Looking for a good authoring software that support using MP4 files to DVD
By LegendaryGamer in forum Authoring (DVD)Replies: 4Last Post: 10th Mar 2010, 16:04 -
Authoring a DVD with updated audio files
By Turbo Sensonic in forum Authoring (DVD)Replies: 2Last Post: 28th Jul 2007, 06:25
