Results 1 to 30 of 49
  1. What do you do to keep your PC safe from Virus spyware and hackers?
    Well I got the worst virus I have ever had really do not know how I got it but I think I turn of my virus software to have another program run better. When i went to reboot I had the virus in the boot up.
    Had windows 2000 as my OS and my hard drive was set to master not duel master. Some reason Windows 2000 install fine 18 months ago. Now I could not even install windows 95 LOl nothing would go in.
    I tried to install windows Xp after 2000 would not go in. It installed and crash every 10 to 15 minutes. Took the hard drive out to format it on another PC as a slave. Also my 2000 and XP CD could not even format the drive.
    After taken a look at my hard drive manual I found out the set had to be for duel master also upgrade my bois.
    Also I have seen this problem before you some can only have one hard drive ona IDE cable when install windows or any OS I would think.
    After I got windows back up I said never again will my host OS ever go on the net ever again. Oh ok I lied I went to Microsoft website for updates LOL.
    Now I use Virual PC 2004. After you install Virual PC 2004 you need to install Service pack 1. Then after you install any OS you want you have to do another update click on "action" install updates.
    After I did this the fake guest OS is running so go no lag just fine for the net and other things.
    So my real OS will never have Spyware or another Virus in it ever again.
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    Win XP SP 2
    Norton System Works 2002.
    Adaware
    Kevin
  3. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    XP SP2
    Adaware
    AVG A/V
    Works for me
    If in doubt, Google it.
  4. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    WINDOWS 2000 PRO W/ SP 4
    NORTONS SYSTEMWORKS 2003
    AVG ANTIVIRUS FREE EDITION
    SPYBOT SEARCH
  5. "yoda313" Im not try to come down on you but you sound little rude when you reply "HELLO"
    I was running 2000 service pack 4 with AVG free virus software and ad-ware and other Spyware software.
    I had my PC running fine for 18 month before five days ago I got the virus.
    I turn off the virus software I scan for virus ever time there a update from AVG still I got the virus.
    I never use IE I use Mozilla or Firefox or Opera.
  6. Mod Neophyte redwudz's Avatar
    USA
    XP, SP2
    Hardware firewall and router
    AVG free antivirus 7.x
    Spybot S&D
    Protowall ISP blocker
    Windows XP2 firewall (Somewhat used)
    Spyware Blaster
    .....And being careful where I go on the internet and even more careful of what I download.
  7. Common sense and additional knowledge...
    makntraks
    In the theater of the mind...
    It's always good to know where the exits are...
    Firefox
    Teatimer
    Spybot
    custom entires in the HOSTS file
    Norton Firewall
    Norton A/V
    Hardware firewall and other security in router
    8½x14 paper in the printer
    .... and a voodoo doll :P
    Keeps away spam, virus, trojans, malware, spyware, etc.
    All the crap nobody wants.
  9. Banned
    Sep 2004
    Inner Circle of Thought
    Xp SP2
    Norton Antivirus Corp. Edition - Updated Daily
    Hardware router and Firewall
    Spybot Search & Destroy
    Ad-Aware
    Mozilla Firefox as default browser
  10. Serene Savage Shadowmistress's Avatar
    Mar 2004
    Controlled Chaos
    I use absolutely nothing. Nada. Zip. Zilch.
    If I pick up an accidental virus, or 20... it takes me 7 minutes to clean out my system with nothing lost.
    I have 2 physical hardrives.
    Primary = C:\ = 4 GB = Windows, all software
    Secondary = D:\ = 10 GB = My Documents, movies, email, anything I want to keep.
    I did a fresh install of all my programs a while back. Defragged my system, set all my settings for each individual program the way I like it, and stayed off the net.
    Made a clone image of my C: drive using Norton Ghost 2002 and burned it to cd. Then I surfed like crazy.
    Every time my computer gets totally messed up, I just load the clone and it formats my disk and restores the image along with boot sectors and everything. It takes 7 minutes to restore it like the day I made the clone. I don't even need to defrag. No messing around with drivers and patches for me.
    I keep all my documents which accumulate more frequently on my D: drive. I burn that occasionally "just in case". I keep all my sensitive material on cd and not on comp.
    When I wish to install a new program, I'll test it first and if I decide to keep it, I do a fresh restore, install the program and then make a new clone on cd. (Sometimes I'll just wait and do several at once.)
    The only drawback of this method is that I have to go in and copy my internet links folder before I restore, then merge it back afterwards.
    Average time between restores: 5 months
    Average time between thanking God I took the time to do this: Everyday
  11. Short of running DOS and never accessing the Internet -- I do as Bazooka does.
    While the former is guaranteed -- the later is pretty good if you are diligent and keep everything updated and scanned frequently!!
  12. Member richdvd's Avatar
    Oct 2003
    Toronto, Canada
    He has said "HELLO" in all of his 15,000 posts or so. :P
    Yoda is very polite, that's all.
  13. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    Thank you richdvd....
    Spiderman2k1 - It's just something I started doing and never stopped. What's RUDE about saying hello??????
    Kevin
  14. Master of Time & Space Capmaster's Avatar
    Feb 2004
    Denver, CO United States
    Norton Systemworks/Antivirus 2003 and Spybot S&D
  15. "yoda313" I'm sorry then i took it the wrong way.
  16. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    No problem - it's just the way I do things here
    Kevin
  17. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    What other way can you take Hello ?
  18. Master of Time & Space Capmaster's Avatar
    Feb 2004
    Maybe he took it like when someone says something stupid and you reply:
    "Ummmm ....Hellooo???"
    He just doesn't know Yoda, that's all.
  19. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    WHAT--EVER !!!
  20. Spybot S&D
    Adaware
    Windows Startup Inspector
    Firefox
    McAfee Firewall
    Avast! Antivirus
    And I run linux a good portiion of the time.
    Check out www.spychecker.com for a bunch of apps.
  21. Member shelbyGT's Avatar
    Oct 2003
    Kansas City, KS
    XP SP2
    Symantec Corporate Edition AV
    Zonealarm (free kind)
    Adaware every week or so
    Don't download stuff from ipodfreepron.org
  22. Member VideoTechMan's Avatar
    Apr 2003
    Michigan, USA
    Hmm what do I do to keep my PC safe from virus software?
    Simple--keeping my PC disconnected from the internet. At least for my AV PC that I use to do my video work, I dont use the internet at all on it, and I have no ethernet cables connected to it so I know for sure my system is safe. Only time I use the internet with it is when I need to download necessary updates for some of the software I have. Otherwise the internet doesnt exist on that PC. I do my surfing on my laptop, and use Mozilla as my browser.
    And like another poster mentioned, common sense also can help .
    VTM
    I have the staff of power, now it's up to me to use it to its full potential to command my life and be successful.
  23. Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    Patched to current level, norton 05, and firefox. Done.
    Also if the machine does get infected I turn to my Mac and surf away.
  24. WinXP SP2
    AVG
    AdAware
    Windows Firewall
    Common sense
    Last trojan/worm/spyware infection? Never.
    Regards.
    Michael Tam
    w: Morsels of Evidence
  25. Member
    Mar 2002
    Hawaii
    W2K SP4
    AdAware
    Firefox
    I've never had a virus. *cough*
  26. Member p_l's Avatar
    Montreal, Canada
    -Windows Update
    -Hardware router and Firewall
    -ZoneAlarm Firewall
    -Norton Antivirus
    -AdAware
    -Spybot S&D
    -Google Pop-Up Blocker
    -common sense (i.e., don't open email attachments from people you don't know, don't click Accept or OK when web sites want to install something you haven't asked for, just say NO, etc.)
    -luck
    No viruses yet (at least not the computer kind ).
  27. Member
    Jul 2002
    Up in yo' bitch.
    Mcafee A/V
    Adaware
    Hardware Firewall
    XP SP2
    Since SP2, I haven't had any real issues with viruses, pop-ups, unwanted active x controls, etc...
  28. Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    Originally Posted by smearbrick1
    Hardware Firewall
    Ding! Ding! correct! Get a router with a firewall at least people,even if its just one connection on your broadband being used. Software firewalls suck.
    I like the wall built into D-Link routers personally.
  29. Member
    Mar 2003
    I run a router with a built in firewall and Mac OS 10.3
    The is no adware or spyware for it and there are no real viruses out for it
    For now at least
    (There was one report by an antivirus company in Europe but they said the never "found it in the wild")
  30. Azrail - Angel of Death Azrail's Avatar
    Oct 2010
    Hell
    WOW girl, so u must be a real computer expert! I have some questions. How do u know which parts of your computer
    are infected with the virus or malware? and how do u remove them? i want to know
    thanks
