I was able to burn DVDs until I reformatted my computer...now I get this error...
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 1/29/2003 8:37:36 PM
Nero API version: 5.5.10.15
Using interface version: 6.3.1.4
Installed in: C:\Program Files\Ahead\Nero\
Application: ahead\Nero - Burning Rom
=== Scsi-Device-Map ===
CdRomPeripheral : MITSUMI CR-48XATE atapi Port 0 ID 0 DMA: On
CdRomPeripheral : ATAPI DVD RW 8XMax atapi Port 0 ID 1 DMA: On
DiskPeripheral : WDC WD740GD-32FLA0 21.0 viasraid Port 2 ID 0 DMA: ?
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 1023MB (1048048kB)
Free physical memory: 756MB (775000kB)
Memory in use : 26 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Enabled (1)
22.12.2004
NeroAPI
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Does anyone have ANY idea what this error means?
When I try to burn with Nero, it says it fails because it cant perform "End of Disc at once"
I just want to burn a dvd!
You could try installing (in the correct place) the official nero Wnaspi32.dll file from here. Also if you do a search for Wnaspi32.dll at support.microsoft.com there are some articles there about this sort of problem occurring after a Windows upgrade. These articles point to totally deinstalling Nero and reinstalling, which would be a good option if the above download doesn't help.
Regards,
Lee. -
check the nero/ahead web site www.ahead.de - support - utilities Link. There are links to download tools to completely uninstall/remove all traces of Nero from your system.
***Be sure to write down your license number before uninstalling/using these tools!!!***
If you install an (adaptec) aspi layer, I would also advise AGAINST using the latest Adaptec ASPI driver (4.7x versions) - at least in Windows XP. I can't comment on other operating systems. Instead - and only as a last resort - try installing the Adaptec ASPI 4.60. If you have already installed a version newer than 4.60, do a search for "ForceASPI" - a utility that will allow you to install 4.60.
The 4.7x versions are known to be problematic.Some people say dog is mans best friend. I say that man is dog's best slave... At least that is what my dogs think.
VirtualDub Error Message - Video Compression Error
By HartsVideo in forum DVD RippingReplies: 19Last Post: 7th Jun 2009, 20:18 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 16:41 -
Error Message
By Perfik in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 3rd Jul 2007, 12:45 -
Error message "CMOS checksum error - Default loaded"
By ChrisKS in forum ComputerReplies: 1Last Post: 27th Jun 2007, 01:16 -
Error Message
By Kallid in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 15th Jun 2007, 20:13
