  1. Hi guys, I came across a problem with my burner/s today. I tried burning a DVD with my Liteon 401s (ES0M/FW) using dvd-decryptor and i kept getting errors, I forgot to copy the error, i apologize. So i tried my new dvd burner, Optorite DD0405 and i got the same error (which i copied this time :
    E 22:06:41 Failed to Write Sectors 537120 - 537135 - Logical Unit Communication CRC Error (ULTRA-DMA/32)
    Now it was all working fine before, ive been using the same process for a few months now, so im not doing nothing new. Now i cant even burn cdrs cos the new dvd burner doesnt allow me to select a speed to burn at, nero shows 60x but no option, and the cd burn process fails at the end (fixation error). Ok it will auto-select the max write, but i want to try and write at half the speed to check.
    Ive not installed anything new, so im stumped @ this problem. Any help here guys will be appreciated....Thx SasArchiver
    AMD 2200+ (1.83ghz), 512DDR PC2700 (333mhz)
    160GB Hitachi 7,200rpm 1mb cache, 80GB Western Digital/7,200rpm HD
    ATI Radeon 9600xt 128mb 8x, KT4 Ultra FSB 333 AGP 8X/ D bracket
    DVD+R/DVD+RW/CD-r/CD-RW,Antec Plus 1000 Case with lights
  2. nae suggestions?
  3. Banned
    Sep 2004
    Inner Circle of Thought
    Bad discs and possibly a dirty laser lens
