I read in this site that a VCD video has a bitrate of 1150 kbit/s. SVCD has up to 2600 kbit/s.
If I create a VCD with 1500 kbit/s, for example, it will result in loss of space without increase quality?
If it isn't possile, I only can make movies with bitrates higher than 1150 on SVCD?
The movies in question will be made to watch in a standalone DVD Player.
Thanks in advance
If you make a VCD with a higher bit rate than 1150Kbits per second it will actually be an xVCD and the higher the bitrate the better the picture quality - have a look here:
https://www.videohelp.com/xvcd.htm
It may play on your DVD player (or nowadays should). Try it out on a CD-RW and see if it works.
Or alternatively, have a look if your DVD player will play XVCDs here:
https://www.videohelp.com/dvdplayers
Hope that this is helpful.Cole -
Originally Posted by F u r u y á
http://www.videoehlp.com/svcd
VCD is 352 * 240/288 1150kbps video, 44.1KHz 224kbps MP2 audio. end of story.
SVCD is 480 * 480/576 video, 44.1Khz MP2 audio, with video able to go up to 2600, audio to be between 32 & 384kbps, with the total combined bitrate not to exceed 2778kbps.
If you go outside these specs, you're looking at (X)(S)VCD's.If in doubt, Google it. -
I created a VCD with 1400 kbit/s and my standalone DVD Player ran it just fine.
My question is:
Did my DVD Player run that VCD with its bitrate (1400 kbit/s) or it ran with 1150 kbit/s, loosing the extra bitrate?
And, is there a difference in the quality beetwen VCD and SVCD, both with same bitrate (1400 for example)?
how to set max bitrate in dvd architect
By ejparle in forum Authoring (DVD)Replies: 1Last Post: 19th Feb 2011, 16:44 -
Need help to set up Variable Bitrate
By spigy in forum Video ConversionReplies: 19Last Post: 16th May 2010, 13:13 -
x264, set quantizer to 10 and vary keyinterval to reach set target bitrate?
By frifox in forum Video ConversionReplies: 6Last Post: 20th Feb 2009, 15:59 -
How to set optimal bitrate for MPEG
By peterbuilt in forum Newbie / General discussionsReplies: 2Last Post: 17th Mar 2008, 11:13 -
How to set bitrate in BeSweetGUI?
By ecc in forum AudioReplies: 4Last Post: 8th Nov 2007, 10:00
