I am wondering, if it is not for music content, does audio encoding to DVD mp2 in 192, 128 or 112 make any difference that the ear can detect? I cannot hear any my self concerning VHS material with family content (no music).
112 seems ok to me and the space loss is minimised....
Results 1 to 17 of 17
KONX OM PANX
Hi Phoebos,
If it's non-music and you can't hear the difference / are happy with the end product then go for it.
I've usually seen 128 recommended as the minimum with 192 as the preferred, though I don't recall why.
If space is absolutely crucial, and 112 helps just that little bit, then fair enough. But, if not, then why not have 192 and that bit better audio anyway?There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
112 is just fine for voice, etc. but if you want quality music then definitely go for the 192.
Or if you are using the native TMPG audio encoder go for 256k. This is also the bitrate used for BBC Digital TV sound.
192/224/256/384 for 2/0 ... not really
anything less.... YES, big drops in MP2 or AC3.Want my help? Ask here! (not via PM!)
For voice only 128 is good enough.
The bitrates quoted all refer to 2ch (stereo/dual/binaural) audio. If you really aren't doing music as main focus--just voice, etc--then save a bundle (1/2 the size in fact!) by doing them as 1 channel.
Then, your 112/128/192/224 choices become 48/56/64/80/92/112 choices (with the same perceived quality per channel).
HTH,
Scott -
Yes, the built-in audio encoder in TMPG isn't the best. This is especially so at lower bitrates. If you are using Toolame than you can go for lower bitrates and still have the same sound quality. With Toolame, use at least 192k stereo or 96k mono.Originally Posted by Phoebos
FYI if you encode to 2.0 dolby and use a bitrate lower than 192kb/s you're cutting the frequency bandwidth (higher frequencies get cut).
Whether this is ok for voice/dialogues it's up to you to decide.Sorry, I had to go see about a girl -
I wouldn't go lower 192kb/s for mp2!
It has to do with the things our brain hears but our ears don't!
Less headaches for sure when you use 192kb/s for mp2! In a way it's like mp3 at 128kb/sLa Linea by Osvaldo Cavandoli
In fact VHS can be a source of high quality stereo sound. I'm speaking of commercial tapes and not home footage like in the original post.Originally Posted by funkguy4"Art is making something out of nothing and selling it." - Frank Zappa
192 vs 96 vs 48 vs 44.1 KHz?
By therock003 in forum AudioReplies: 22Last Post: 19th Nov 2012, 10:55 -
128 kbps to 96 kbps MP3 - big difference?
By joshua4 in forum AudioReplies: 12Last Post: 24th Oct 2008, 15:11 -
pioneer having problems with 112 drives
By aedipuss in forum DVD & Blu-ray WritersReplies: 2Last Post: 24th Dec 2007, 07:50 -
Should I get a Pioneer 112 or a Liteon 20a drive?
By heman31 in forum DVD & Blu-ray WritersReplies: 3Last Post: 12th Dec 2007, 12:05 -
Pioneer 112 or 112D?
By blacktooth in forum DVD & Blu-ray WritersReplies: 1Last Post: 24th Aug 2007, 18:09
