Results 1 to 18 of 18
  1. Hi
    Having trouble converting avi to dvd with WinAvi. I get audio on the pc but not on the dvd player. In fact itīs worst than that: as soon as the audio starts (after the production screens with no audio) the player freezes.
    From this batch the only one that worked is a movie with ac3 audio and winavi with directac3 enabled. The others that have mp3 audio none worked.
    Any thoughts on this?
    J
    PS - I googled this and could only find probs related with a/v sync.
  2. What model DVD player?..I bet in dosent support Mp3.
  3. Youīre right, it doesnīt.
    But it does light up pro logic in the display which is confusing...
    To what format does winavi encode the audio?
    What software can give me accurate a/v properties (like gspot for vob files)?
  4. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    GSpot should be fine for identifying most files, or AVICodec.
    Yet another reason not to use a 1-click app IMO. Options and flexibility
    If in doubt, Google it.
  5. Ok according to VDubMod all movies were encoded with 48KHz, 224kbps AC3 audio but I still donīt know audio fps.
    All were encoded in 23.976 which (I think) can be a problem since ntsc dvd spec is 29.97 - thatīs because I usually set everything in winavi to AUTO and Iīve had good results in PAL - except for one movie which is already 29.97 fps but the exact same thing happens: as soon has the first sounds appears it freezes.
    I think it means that itīs audio related but I still would like to see what are the fps on the audio - what software does that?
  6. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    AFAIK there's no such thing as fps on the audio - that's what the 48KHz means - 48,000 samples per second.
  7. jimmalenko
    in gspot v2.21 opening a vob file doesnīt produce any useful results.
    avicodec on the other hand produce interesting yet odd results - according to it my videos are all 29.97 (audio same spec as VDubMod).
    Which one should I believe?
    But more importantly what is the prob with these dvdīs?
  8. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Sounds to me like WinAVI either left your 23.976fps as is and added 3:2 pulldown on playback, OR re-encoded to 29.97fps. Either way, I don't think that's the real cause of this issue.
    What happebns when you play the output files off your computer's hard drive (in IFOEdit, PowerDVD or WinDVD) ?
  9. If you load the AVI file into VIRTUALDUB first and then compress the audio to NO COMPRESSION PCM you will find when you put it back into WINAVI you will have sound
  10. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    ... you might find that you end up with PCM audio in your end product too, if you're not careful. This takes up HEAPS of space
  11. jimmalenko
    on the pc every movie plays ok
    and iīm pretty sure that thereīs something besides frequency and bitrate, which i call "audio fps" and is needed to sync a/v
    jayt
    iīll try that and post back although Iīve done this before with mp3 and got audio
  12. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    It's certainly not a standard, I can tell you
    You synch audio by making the durations of video and audio match AFAIK.
  13. I think I know what the problem is: all aviīs have VBR mp3 which can be causing this trouble.
    For testing purposes I was thinking of demuxing audio from avi, converting to AC3 with something like besweet and then muxing back to video.
    but Iīm not exactly sure on how to perform the muxing step... what software and how?
    PS - does this mean that winavi canīt deal with vbr mp3?
  14. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    If you want to demux and then remux back to the AVI, Virtualdubmod would be my tool of choice. If you want to demux, then convert the video stream, then remux in the authoring stage, you'll need an encoding software to output to elementary streams (TMPGEnc Plus, CCE ... or demux WinAVI's output), and authoring software that can accept elementary streams or allow you to specify a different audio stream (TMPGEnc DVD Author, DVD-lab).
    Does this mean that winavi canīt deal with vbr mp3?
    Quite a lot of encoders/authorers can't so it wouldn't surprise me.
  15. jimmalenko
    I want to demux and then remux back to the AVI using VDubMod.
    Any chance you could guide me through those steps since Iīm not sure how to do it?
  16. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    In virtualdubmod, open AVI. Go to streams > stream list, right-click on the audio stream and select Full Processing, then click the Save WAV button. Load this WAV into ffmpeggui and convert to AC3. Go back to Virtualdubmod, select the old audio, press the disable button, click the add button, and add your new AC3 file. right-click on the AC3 stream and go to direct stream copy. Click OK button to exit streams list. Go to video > Direct stream copy. Go to File > Save As ... and save out to a new AVI file. Now your VBR MP3 audio has been extracted to a WAV, converted to AC3 and re-added back into a new AVI file.
  17. OK. It definetly worked for me.
    Enabling directac3 in winavi with the new aviīs already with ac3 audio everything works fine.
    But still something puzzles me... when you "save wav" in VDubMod you get mp3 file but when you load it to besweet (thatīs what iīm using not ffmpeggui) it recognizes it as wav and the conversion is "wav to ac3".
    Could this be bad in any way? The result seems fine.
    Thanks everybody for the help especially jimmalenko
    J
  18. just a side note, i've had problems w/ silent AC3s coming out of BeSweet. and it's probably saying WAv -> AVI because the Save WAV in VDubMod puts a WAV header on it (just like the regular VirtualDub when you Save WAV w/o oing full processing mode.
    My AVI -> Any Format Guide is available here.
    My Frame Resize Calculator (enhanced for Virtualdub) is available here
