any tips?
Default seems to be 192 kbits/sec for TMPGENC plus 2.5
Also, im just a young padowan in the Conversion/DVD authoring arena, so i dont yet have a vast knowledge of how things work, while keeping that i mind i ask this:
It seems that i can make DVD audo in the following:
CBR Linear PCM
CBR Mpeg 1 layer 2
VBR Linear PCM
VBR Mpeg 1 layer 2
Are they all "dvd compatible", and by that i mean would they play universally on all dvd players? If not, then which one is?
Also, what would be the best bitrate-to-type combination that will give me the most quality for the least amount of space...
for example, VBR Mpeg 1 layer 2 at 128 kbits/s ???
It depends on the source. If your source is 224kbps AC3, then using 1536kbps PCM isn't going to improve the audio. Also, "sounding like crap" is a subjective measure - it depends on what sort of audio set-up you have (5 speaker, 1 subbie surround sound will sound a lot different to a pair of dodgy PC speakers).
VCD is 224kbps, so because I only use the inbuilt TV speakers, I make everything 224kbps and that's good enough for my TV/VHS caps or downloaded stuff.
That VBR and CBR is referring to the video - for DVD, you can't use VBR audio. Linear PCM takes up massive amounts of room, and MPEG 1 Layer 2 audio is not part of the DVD spec for NTSC on its own. IMO you'd be better off just converting the video with TMPGEnc, then using either ffmpeggui or besweet to convert your audio to an AC3 audio file, which is dvd-compliant for both PAL and NTSC. See What is DVD for the DVD specs.If in doubt, Google it.
How to set MINIMUM bitrate in VBR 2 -pass on TMPGEnc Authoringworks 4
By eltimbomofo in forum Authoring (DVD)Replies: 3Last Post: 9th Mar 2012, 15:59 -
Minimum Bitrate MPEG2 encoding
By Rob D. in forum ffmpegX general discussionReplies: 4Last Post: 14th Jul 2010, 09:44 -
WMP 10 won't play CD's the audio is all choppy sounding, mp3's are fine..
By J Tinsby in forum Software PlayingReplies: 3Last Post: 14th Dec 2009, 05:32 -
TMPGEnc makes deep/slower sounding audio
By awesomer in forum Video ConversionReplies: 8Last Post: 28th Oct 2007, 00:46 -
cut sounding noises // decompression (VDUBMOD)
By y0ustinK in forum SubtitleReplies: 1Last Post: 11th Aug 2007, 10:35
