Just converted an mpeg file to vcd and svcd using ffmpegx and
my dvd player (desay ds-5701) can't read it even though it does
read other vcd's i've done with a dual deck.
I am using ffmpegx 0.0.9k and used the "fast svcd" preset.
Can anyone help??? THANKS!!!![]()
Some DVD players may not like SVCD/VCDs made with ffmpeg engine, as they may include bitrate peaks (even more important in older versions like 0.0.9k). Use mpeg2enc engine.
https://www.videohelp.com/dvdplayers.php?DVDname=desay+ds-5701&Submit=Search&Search=Sea...y=Name&hits=25Originally Posted by billrobins2
That player ought to play either fine.
Maybe ....bad media, or something wrong in the presets. Try manually authoring the files. Check the "What Is" section for the allowed resolutions, bitrates and audio formats/settings and double-check your settings, changing as needed. then try again. If it fails again, I'd say you might have a player/media incompatibility issue
In fact in ffmpegX 0.0.9k you should select the quick preset named "DVD hi-bitrate".
Please email me to major4@mac.com with the following information:
- name of your startup disk
- location where you installed ffmpegX
VCD to DVD (not SVCD)
By noyou in forum SVCD2DVD & VOB2MPGReplies: 20Last Post: 19th May 2009, 17:56 -
Encoding VIDEO_TS to mpeg-2 SVCD
By phamtom in forum ffmpegX general discussionReplies: 6Last Post: 27th Apr 2008, 16:05 -
MOV to MPEG-1 with ffmpegX on Mac; doesn't play on PC
By mopkba12345 in forum Video ConversionReplies: 1Last Post: 20th Feb 2008, 11:52 -
exporting as MPEG-TS in ffmpegx
By remp in forum MacReplies: 4Last Post: 22nd Jan 2008, 21:30 -
Convert mpeg-4 to mpeg-1 with ffmpegx?
By CollinH in forum ffmpegX general discussionReplies: 2Last Post: 22nd Sep 2007, 23:36
