I just re-installed my Windows ME
Installed Tmpeg 2.01 and divx codec 4.1
But now - when i try to open a divx file in tmpeg - i get
"format not supported".... what the h*** is going on?
Anyone got a solution... really need to convert som
divx files to svcd!!!
You must install DIVx codec version 3.11 as TMPGEnc doesn't work with version 4.11 of the codec.
I disagree. Divx 4.11 works very nicely with TMPGEnc, but if you didn't install 3.11a previously, you may be missing an audio codec that is required by some Divx-files.
One thing that you might try in TMPGEnc is to give the "DirectShow Multimedia File Reader" a higher priority (under "Option" > "Environmental setting" > "VFAPI plug-in".
I'm having probs with MPC-HC
By HartsVideo in forum Software PlayingReplies: 8Last Post: 10th Feb 2011, 20:47 -
A few probs with FAVC
By kronick in forum Video ConversionReplies: 9Last Post: 15th Oct 2008, 19:25 -
Something better Tmpeg Enc
By 02fx4dude in forum Video ConversionReplies: 4Last Post: 15th Aug 2007, 06:23 -
Tmpeg 2.5 will not encode .avi
By WuTangDvD in forum Newbie / General discussionsReplies: 9Last Post: 20th Jul 2007, 13:01
