I have just starting to capture TV programs from my Cable TV.
I'm using WinDVR to cap to MPEG2 which I would like to encode to DivX.
Now, if I encode at
[Real-time Best]
Format: MPEG-2
Audio:
Format: MPEG-1 Layer II
Sampling Rate: 44.1 kHz 16-bit Stereo
Bit Rate: 224 KBits/sec
Video:
Frame Rate: 25.00 frames/sec
Bit Rate: 7200 KBits/sec
Should I be expecting a near perfect cap? Because it doesn't seem very good to me.
http://www.nickday85.pwp.blueyonder.co.uk/quality.gif
-Nick
Results 1 to 15 of 15
if the end product is divx, dont capture to mpg2, capture using mjpg or huffy and do your edits in virtualdub and save as divx
What if I wasn't planning to encode to DivX though?
I have tried capturing with those codecs too, but I get the same results. I'ts certainly not clear like it should be considering the codecs are lossless.
I know it's not the signal, because I have captured using Windows Movie Maker and the signal is top class.
It's kind of annoying me, as I've seen and downloaded TV rips from a friend and his are normally around 24 mins long, DivX and brilliant quality. What am I doing wrong?
-Nick -
wats ur connection from tv to pc?
Originally Posted by stixsterWell, which is it ?Originally Posted by stixster
You ask one question, then ask the complete opposite !!!
That pic you posted looks totally normal to me for a TV cap. What you'll find is that TV caps normally have noise, and you need to do some noise removal on them. Also, the noise shows up far worse on a PC screen than it will on a TV, because your DVD Player and TV have noise removal features within them by default.
There's a guide here which shows you how to use the convolution3D filter with AVISynth, or a number of MPEG encoders have inbuilt settings also.
BTW, if your "friend" gets such good quality, why don't you just ask him how he does it ? Warez someone like me to find a friend like that ???If in doubt, Google it. -
I see what you've done. You taken 2+2 and got 5.BTW, if your "friend" gets such good quality, why don't you just ask him how he does it ? Warez someone like me to find a friend like that???
When I say friend, I mean friend. Warez is illegal wheras what my "friend" does is not.
Is it illegal to use your VCR? No. What he simply does is record things for people who do not have the facilities to themselves.
Please do not accuse me of illegal doings. All I'm trying to do is get the best quality I possible can out of my TV Card.
-Nick -
No accusations here, my friend. If it weren't true, you'd laugh it off, wouldn't you ?Originally Posted by stixster
BTW, it's not illegal to use your VCR for your own purposes, but recording things for other people (ie. uploading to "friends") is dicey at best.
I'd still just ask your friend how he does it ....... if you can find the email address in the readme.txt
j/k
I asked him this morning actually. He told me, and I did what he said, but still I get a crappy cap.I'd still just ask your friend how he does it ....... if you can find the email address in the readme.txt
j/k
All I want to know is what settings to run Dr. DivX at? I've used GSpot on my friends caps and they all say 1004Kb. Now, if I use that I get pixelation galore.
Can someone shed some ideas?
-Nick -
IMO you need to split this up into two areas - the capture and the re-encode. Each area must be finely-tuned for you to get the results you require. Now starting at the end first, 1004kbps IMO should be OK for a 640 X 480 XviD/DivX, provided your source is decent. So back to the start, you need to make sure you're getting the best possible product when capturing, in order for the re-encode to XviD or DivX to have the best possible source.Originally Posted by stixsterIf in doubt, Google it.
I capture VHS and cable TV into DV via an ADVC-100, then apply noise removal on it, then a deinterlace if they're only going to be watched on a PC, or use a player that deinterlaces properly such as PowerDVD.
In your case, since you said earlier that you are getting an excellent signal with Windows Movie Maker, why not capture with that, and output to DV-AVI, then re-encode that to DivX ?If in doubt, Google it. -
Yeh, I was thinking about that, but how do I encode to DV-AVI? It's greyed out on my copy :S
-Nick -
Grrrrr. I don't get that. Is it because I don't have a DV Cam?
If so, I'm well pi**ed because that's giving me the best signal.
-Nick
Screen capping on computer, XviD codec misbehaving?
By CursedLemon in forum Capturing and VCRReplies: 4Last Post: 13th May 2011, 00:43 -
Problem with capping on my comp with WinDV and advc-100
By MikeMGMVE in forum Capturing and VCRReplies: 3Last Post: 2nd Oct 2008, 14:19 -
Capping BBCHD H.264 Help plz...
By 77x8 in forum DVB / IPTVReplies: 2Last Post: 14th Jul 2008, 06:16 -
What screen capping/thumbnails software is this
By Ronny G in forum Newbie / General discussionsReplies: 8Last Post: 19th Mar 2008, 07:36
