I'm in the process of creating my own PC. So far i've only purchased a case. I want to buy the motherboard next, but am having trouble decieding between an INTEL P4 3.4 or the Athlon 64 FX-55. Price is not an issue. My question is about multitasking and application speed. The P4 is 3.4GHz, and the 64 is 2.6GHz, yet all the reviews I've read, inform me the Athlon is faster. Is it because it's 64 bit? Can someone please explain this to me?
Thanks.
P.S. The PC will be used mainly for gaming and multitasking.
Results 1 to 13 of 13
Athlon64
It performs 32bit apps faster and you would be ready for 64bit computing -
The Athlon64 runs 32bit apps better than the pentium4, and you would be set for 64 bit computing- thus eliminating the need to upgrade.
So even though the INTEL has a higher GHz rating, the Athlon will run apps faster? Explain
The gigahertz is overrated.Originally Posted by msb-mike
That is why both amd and intel have gotten away from that kind of marketing.
The pentium4 has more pipelines it has to go through to get the same performance as the athlon64.
The athlon has a better architecture. -
I agree.Athlon64
Friend just built a 3.4ghz Intel. From what I've seen I'd go with the AMD also
Not that you'd want this but I recently read a review on how easy it is to install Debian Linux to an AMD 64 bit, even though its not officially supported. Since 64 bit is the future of computing, you might as well get ahead now and buy a 64 bit chip.
My New Athlon II
By ocgw in forum ComputerReplies: 15Last Post: 26th Nov 2009, 19:01 -
Intel Core 2 Duo T7500 2.20 vs. Intel Core 2 Duo E8400 3.0
By vatkat234 in forum ComputerReplies: 6Last Post: 27th May 2009, 10:42 -
Intel Q6600 Kentsfield or Intel E8400 Wolfdale??? Help me decide which one
By budz in forum ComputerReplies: 33Last Post: 12th Mar 2009, 00:19 -
Encoding - Xp or vista, Athlon or Intel?
By RKDYork in forum Newbie / General discussionsReplies: 6Last Post: 18th Jan 2009, 19:57 -
0.0.9x and pre-Intel
By kwkdy in forum ffmpegX general discussionReplies: 3Last Post: 6th Jun 2007, 08:52
