  1. Hello,
    By trying to convert a AVI-file to a an mpeg-file the next message appeare:
    "The selected file uses an unsupported codec wich cannot be converted using this module".
    I don't understand, because it think the program I use should support it (Blaze MediaConvert) and there is no error or something in the movie.
    Can anyone help me?
    Thanks,
    Rikman
  2. Try using TMPGEnc
    http://www.tmpgenc.com/e_main.html
    It worked great for me, except my darn DVD wont play CD-Rs
  3. Thank you very much!
    The program works great indeed!
    Kind regards,
    Rikman
    <font size=-1>[ This Message was edited by: Rikman on 2001-12-04 09:24:36 ]</font>
