I have had terrible luck with DVD players playing DVD -R discs. I usually burn on Ritek G04, usually regarded as a quality media. I had an Apex, which had a propensity for freezing. Then I bought a DVB312 by Zenith, and I am experiencing similar problems. All movies work perfectly on the computer. Can anyone recommend a good DVD -R media player?
Go with the Phillips DVP642. It plays everything I have been able to throw at it. I to am standard on Ritek G04 & G05 and never have any problems (6 mos).
Sounds like a burning problem. Go with the good quality discs, burn at slow speeds, and use tested software, decryptor, Schrink. intervideos dvd copy.
I user smart ripper 2.4.1
Then I use Intervideo DVD copy to copy to HD, then the same to copy to media.
I use Ritek G04.
Would you recommend changing my methods?
Good PQ DVD Player
By mis3 in forum DVD & Blu-ray PlayersReplies: 24Last Post: 31st Dec 2009, 14:11 -
Looking for a Good Video Player Or DVD Player
By DJboutit in forum Portable VideoReplies: 1Last Post: 6th Jun 2009, 22:57 -
Looking for a cheap and good standalone DVD player
By Kweldood in forum DVD & Blu-ray PlayersReplies: 9Last Post: 28th May 2009, 08:54 -
In need of a good DVD Player
By Jenn11803 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 7th Nov 2007, 11:48 -
Looking for good DVD player with volume functionality.
By parados in forum DVD & Blu-ray PlayersReplies: 0Last Post: 20th Aug 2007, 07:46
