Hi people. I need some help. I have a divx file with AC3 audio. I have to convert the audio to something like mpeg L2 (something that Windowns Media Player recognizes without downloading the condec). I'm asking this because I want to convert it to VCD, and it isn't converting the audio AC3.
Can somebody help me, please ??
Thanks in advance !!!
Fábio
You want a tool called the AC3 ACM Decompressor
FulciLives, could you help me again? I installed, but I didn't understand how to use it with VirtualDub. I didn't find any tutorials too... Could you tell me how it works, or point me to a tutorial?
Thanks !!! -
As I recall you need to do nothing. Just install it.Originally Posted by ffabioo
You should then be able to open up a file with AC-3 audio in VirtualDub without any problems.
I would use VirtualDubMod not the plain version of VirtualDub.
You should also be able to open the file directly into TMPGEnc Plus.
- John "FulciLives" Coleman
P.S.
Reboot after you install."The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
If you're making a VCD then it's best to extract the AC3 to wav and then use the wav file as the audio source when you encode. Here's two guides, I prefer using Goldwave.
Good luck.
"Art is making something out of nothing and selling it." - Frank Zappa -
Thank you, guys !!! I'm converting a movie andI will try this after !!! Thanks again !!
audio problem when converting
By Stevex70 in forum Video ConversionReplies: 0Last Post: 25th Mar 2011, 14:56 -
Converting tv shows audio
By Oem in forum AudioReplies: 3Last Post: 1st Feb 2010, 21:42 -
No Audio after converting
By Seff7845 in forum AudioReplies: 1Last Post: 30th Sep 2009, 04:52 -
No audio converting flv
By holywoodhawk in forum Video ConversionReplies: 0Last Post: 11th Aug 2009, 22:38 -
Converting audio with glitch
By koberulz in forum Newbie / General discussionsReplies: 28Last Post: 7th Sep 2007, 04:55
