All the guides that i've looked at show how to do a slideshow. But is it possible to have categories ( like folders on a computer)?
For example, i want to have 5 categories of pictures, and be able to choose each category seperatly instead of having a huge amout of pictures and having to go through them to find specific ones.
I have never made a picture cd before, so would i be able to disable the slideshow and go through the pictures manually?
thanks for your help.
Unless I'm mistaken, all the files need to be in the same folder. It is part of the VCD/SVCD spec.
You can stop the slide show and go forward or backwards.Google is your Friend -
Yes you can do this easily. SVCDs and VCDs do not operate like photo cds where you just have a bunch of stills in various directories. (S)VCDs support menu capability so you can have a main menu still picture where you select which branch of other mpeg stills you want to view. You just need any (S)VCD authoring software. I recommend VCDEasy.
You can basically do whatever you want. The menu's work by placing commands within each mpeg video or still. So from any menu you can jump to any other menu using number keys, play, stop, etc... You just have to map that button to that link. -
Or you can also use Nero Vision Express 3 and make a slideshow with the pictures in the same file with a refresh of the pictures of the seconds that you want, you can also put a background audio in it.
Should brick and motor websites offer "in store" only search categories?
By yoda313 in forum Off topicReplies: 6Last Post: 23rd Feb 2010, 22:59 -
How many main subtitle categories?
By umforrest in forum SubtitleReplies: 1Last Post: 2nd Mar 2009, 00:29 -
SVCD: Picture is not completely displayed during playback
By czerro in forum Authoring (VCD/SVCD)Replies: 5Last Post: 5th Nov 2007, 14:53 -
vcd playback - flickering picture on one dvd player, fine on another
By i_ming in forum Newbie / General discussionsReplies: 5Last Post: 21st Oct 2007, 08:41 -
Wordpress categories pages as a list?
By lordsmurf in forum ComputerReplies: 2Last Post: 7th Aug 2007, 22:11
