Hi
I would like to know how do i reduce the hiss noise on captured VHS Video?
Clive
Results 1 to 9 of 9
Hello,
You need to extract the audio to a wav file and input it into a audio editor like audacity or a more robust professional package. Many programs have a dehiss option though the results vary from program to program.
Take the cleaned audio file and remux it with the video file. You MAY encounter synch issues. If so check the guides and forum posts here as this has been covered MANY times before
You can also try and see if your VCR has audio out settings. Some have a setting for audio out with choices like Linear/Mix/Hi-Fi, and the setting is set to Hi-Fi by default. On non hi-fi tapes I have found I sometimes get more hiss with that setting, but on linear it isn't as bad.
What I have done for some problem tapes that still have hiss is to run the audio out through my tape deck (high end) and apply either Dolby B or Dolby C noise reduction. Dolby B noise reduction on the source audio is a pretty good alternative to ripping the audio and repairing it later. (as noted, sync issues can crop up)
Regards,
Savant -
Dolby B and C are a compression/expansion system for removing the noise created when recording onto cassettes. They work by encoding (compressing) the signal while recording and then decoding (expanding) it on playback. So in order to work properly Dolby B ideally needs to be used on a tape that was originally encoded with Dolby B, same with Dolby C.What I have done for some problem tapes that still have hiss is to run the audio out through my tape deck (high end) and apply either Dolby B or Dolby C noise reduction. Dolby B noise reduction on the source audio is a pretty good alternative to ripping the audio and repairing it later. (as noted, sync issues can crop up)
Btw, even though I have very high-end software noise reduction, there are times when I want to reduce the noise before the capture and for that I use a Roland NS-50 hardware noise reduction box (used in many recording studios due to the excellent job they do). I've seen them on eBay for around $60 (they used to be $250).
http://www.cycleof5th.com/en/products/sefree/index.htm
Free WAV editor with noise reduction + -
On closer inspection, the noise reduction in this freeware "SoundEngine" works more like the "hiss reduction" in Audition - something I don't tend to touch. Admirable project tho'....
Converting and removing noise/hiss at the same time
By Teac23 in forum Video ConversionReplies: 3Last Post: 21st Jun 2010, 12:35 -
Need advice; using Audition to remove hiss (and noise?)...
By takearushfan in forum RestorationReplies: 22Last Post: 4th May 2010, 04:29 -
Removing noise from video that's possibly from aerial noise/broadcast/vhs
By filnads in forum RestorationReplies: 10Last Post: 11th Jan 2010, 00:57 -
'S' letter hiss (not general hiss on idle!) - help needed
By zee944 in forum AudioReplies: 7Last Post: 21st Sep 2008, 04:54 -
audio becomes a hiss
By ballboy in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 19th Jul 2007, 23:03
