I bought an old movie and discovered it was a colorized version, which I do not want.
Is there anyway to reburn this with the color removed, so it looks as it should?
Results 1 to 14 of 14
You'll be able to re-encode it using the tool of your choice but for simplicity's sake, why not just turn down the colour setting on your TV?
sure - extract it to an mpeg, run it through VirtualDubMod and filter it to b/w, and reauthor.
check the extras on the disc as well - many newer colorized versions include the original b/w version as a bonus.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
housepig:
Did all that and three hours later, I still have a colorized version. I guess I'm not using the filter properly.
If I've already changed it to an mpeg file, what should VDM save it as? -
what steps did you take?
- housepig
Housepig Records
out now:
housepig:
Finally got a BW copy of this damned thing, but no sound!
I d/loaded DVD Audio Extractor and now I am trying to add the ripped sound track to one of the BW copies I have.
I think Josef K was right, though. That's what I've had to do the last two years.
I'll let you know how this turns out. Probably will be out of sync with my luck. -
Or Simply run it through TMPGE.
1) Under Simple Color set R & B to -255
or
2) Under Custom Color set filter to HSV then set Sat to -255.
Works every time. -
Why don't you just put the saturation of the tv down to almost nothing while you watch this one disc? Problem solved, no work involved.
I turn down for PAL discs here, because PAL is overly saturated for NTSC tv sets.Want my help? Ask here! (not via PM!)
Done!
BW version with sound. A total pain in the crack, but I got it done. Plays great on computer, but tends to be a tad jerky on my set-top crappy DVD player (soon to be replaced).
In any event, thanks for all the suggestions folks. Yes, I could keep turning the color down on the TV, like I've done the last two years, but it was the challenge, you know? -
Originally Posted by Slowburn
Out of curiosity, would you mind stating which guides/methods/suggestions you used to complete the process? It'll help anyone in the future wanting to do the same thing if they come across this thread during a search. -
That describes so many video tasks
Josef:
I wish I could write it all down like it was done, but I kept no records or anything. I used four programs for this:
1: DVD Shrink to cut out the extras
2: TmpGenc to go to BW
3: DVD Audio Extractor to capture the audio track that TmpGenc did not.
4: DVD Author to make burnable folders.
I don't remember any settings or anything, just tried things until it worked.
There is probably an easier way, but I'm not about to try it anytime soon.
I need a beer! -
Well, good you got it done in the end...
Changing colors in film to black and white and again colorful with Vegas 10
By siopilos in forum EditingReplies: 12Last Post: 3rd Jun 2011, 12:52 -
DVD Palyer - black and white picture
By majstrydwa in forum DVD & Blu-ray PlayersReplies: 10Last Post: 5th Oct 2010, 10:01 -
DVD with black bars changing
By OrchestraAndChoir in forum DVD RippingReplies: 3Last Post: 26th Jan 2010, 16:59 -
What are the best settings for black and white DVD to H264?
By Emanef in forum DVD RippingReplies: 9Last Post: 9th Nov 2008, 09:35 -
dvd output black/white
By zhanzz2 in forum Newbie / General discussionsReplies: 7Last Post: 12th Jun 2008, 08:46
