I recorded a TV-show and i want to put it on DVD. But the channel logo appears every 10 minutes for a short time.
Is there a conditional filter to remove the logo (or put a black box on it) only when it appears? I know when and for how long they appear each time.
Check the guides on the left hand side and do a search. You can
use Donald Graft's Logo filter with VirtualDub to create
the black box covering fading in and out as necesssary or try the VirtualDub filter " logoaway " or DeLogo to remove the logo. -
Maybe this? https://www.videohelp.com/tools?tool=Virtualdub_Logoaway_filter
Or do a Google search for the others. -
DeLogo has an input box for frames to operate on. For example assume there's a logo for 10 frames at the end of every 100. The line would be:
90-99, 190-199,290-299 .... etc.
There is also the Conditional filter that will selectively apply ANY filter to
selected frames only
:?: how to produce a transparent logo in VDub?
By 3thman in forum EditingReplies: 5Last Post: 8th Oct 2009, 11:24 -
How do I make a filter for VDub
By blaze01 in forum Newbie / General discussionsReplies: 4Last Post: 4th Mar 2008, 16:16 -
Applying a filter without recompressing in VDub
By chrisr34000 in forum EditingReplies: 5Last Post: 25th Jan 2008, 17:42 -
ACDsee Filter&VDUB
By mv0930 in forum Newbie / General discussionsReplies: 0Last Post: 4th Sep 2007, 12:27 -
Vdub Filter Chain
By christopheramos in forum Video ConversionReplies: 16Last Post: 3rd Sep 2007, 07:57
