My son is running Win2K, a recent installation. He installed his ATI card and now every time he starts Windows a folder appears on his desktop as a window. The path is c:\program files\ATI\Support.
There is nothing in the startup folder causing this, and I couldn't find an instance of that path using a search in Regedit.
I used to know how to remove it in Win98, but it was a long time ago. Forum search here didn't show me a post I seem to remember about this. I also did a search at NT Registry Tips & Hacks and I was overwhelmed by the volume of hits I got.
Anyone have a clue how I can remove this damn folder from his desktop?
Easy, get rid of the card :P
Sounds like something may be accessing it on shutdown which is causing it to reappear on boot. I bet there's something in the driver settings that could be the problem.FB-DIMM are the real cause of global warming -
Solved. It resulted from an incompletely installed ATI control panel applet that was in the registry under "Run". If a gegistry key has a bad path or invalid characters it can cause the folder to appear like that.
I removed the applet call and it boots now without the folder 8)
Thanks for the help -
Cap,
You could just delete the folder. This would do away with your problem. However, what ever process is trying to open the folder would probably still run on startup (although with no consequence). Did your son change the installation path when running the ATI installation program? Perhaps the program coding isn't so good and the location is hardcoded within it. Before trying anything else, I'd download the official catalyst uninstaller tool, boot up in safe mode, deinstall the drivers, run the tool you just downloaded, use the default vga drivers and then reboot and reinstall the ATI drivers using the default paths. If that doesn't cure the problem, repost and we'll investigate it further.
Regards,
Lee. -
Or you could do what you already did. So that google search did work then?
Regards,
Lee. -
Originally Posted by dobbin_uk
The forum search here for ATI startup folders yielded nothing, so I went to Microsoft and started poking around there. It paid off this time
Thanks for the help Lee
batch dvd ripping - output folder to input folder?
By mkv2avi in forum DVD RippingReplies: 5Last Post: 17th Apr 2012, 16:23 -
Wgat would be the proper folder structure to add movie cover to a folder
By VoodooEvil in forum Newbie / General discussionsReplies: 1Last Post: 9th Feb 2012, 19:09 -
WPDNSE folder inside your system Temp folder????
By MozartMan in forum ComputerReplies: 25Last Post: 27th Mar 2011, 08:35 -
Only White Video appears
By 911alertme in forum ffmpegX general discussionReplies: 3Last Post: 1st Oct 2008, 17:44 -
Possible to edit what appears when right clicking folder? Sample inside
By Denvers Dawgs in forum ComputerReplies: 2Last Post: 7th Feb 2008, 21:25
