  1. I have K lite codec pack installed and vobsub but OGM files are not playing correctly. Media player classic is unable to show the subtitles (sutitles menu is disabled). RadLight player is unable to play the subtitles as well. And lastly, Bsplayer can only play if I select audio 1, then audio 2 and audio 1 back again. If I select audio 2 it won't play, no video and no audio. If I select audio 1 it will play but I can't turn off the subtitles. WTF?!?!
    Wh............???? Tried Windows Media Player but it's even worse!!!!!!!!!! Both audio channels play at the same time and sound crappy "TTtzzz!!! ZZZZZ!!!!! BBBZZZZZZ!!!"
  2. Give us a Gspot readout on your AVI
  3. replaced k lite wit "all in one" and it worked!
  4. Still not working properly
    Sutitles won't show if I change the resolution to anything but 1024 x 768.
    Dec 2004
    Australia
    Only thing Media Player Classic needs for ogm playback is a vorbis decoder like corevorbis. It has an ogm splitter built in, multiple audio stream support and a subtitle filter.
    Should point out though that for the subitles to work output needs to be set to VMR7/9. If you want to use overlay then you would need to install say VSFilter.
    Codec packs are EVIL by the way.
