  1. I am using DVD shrink3.2 and DVD decryter to burn on a Matrix +R disc. About 1 in 3 movies I burn, seem OK the first time I play them. But the second or third time I watch them, they begin to "break-up and freeze. I clean my player and it still does it, even in a different player.What could be the problem? Could it be the Matrix brand DVD, or do I need a better quality player, or perhaps something else ? Thanks, Rick
  2. Banned
    Sep 2004
    Inner Circle of Thought
    I would say it is bad discs.
    Apr 2002
    The State of Frustration
    Are any of the disks labeled? Labels on poor quality disks make them bow, causing the problems you mentioned. Soaking the disk in warm water for 30 minutes can remove a label. If they aren't labeled, burning them to the halfway point is a workaround as well.
    Hello.
  4. Yes, I do put label on them all. I will not put labels on after burning to see if that helps. Also will try better grade disc. Thanks for the help.
    Rick
