Hi,
I've a dvd burner NEC-ND2500A. Works great. I tried first to make a multisession dvd with nero 6.6.
I select all the options but in burning options I can only select "Dist-At-Once". The option "Track At Once" is not available.
So I can write my disk in multisesssion, add sessions to it with no problems.
I only have problems when trying to read it. In the burner, I can see all the sessions but if I put it on my dvd reader, it only see the first session.
Is it normal with dvd's??
dvd burner:
dvd reader:
Moving to DVD Writers forum ....
You cannot do multi-session for DVD-Video.
Only for computer data. Even then, not suggested.Want my help? Ask here! (not via PM!)
Ok, so I will use DVD-RW to do multisession disks. And when it will be full I'll burn all the datas on a dvd-r
You can not do multisession with DVD-r media. Only use DVD+r for multisession purposes.
why can't I produce an ISO from a multisession track DVD ?
By Bansaw in forum Newbie / General discussionsReplies: 5Last Post: 20th Dec 2010, 11:43 -
Multisession DVD Burner and Burning Files into Specific Folders
By Disco Makberto in forum ComputerReplies: 9Last Post: 23rd Feb 2010, 02:48 -
Will Nero 7.0 do a Multisession DVD
By scustalow in forum Software PlayingReplies: 6Last Post: 1st Oct 2008, 13:16 -
Can only read the first session in a MultiSession recorded DVD?
By demf in forum DVD & Blu-ray RecordersReplies: 1Last Post: 19th Sep 2007, 12:16 -
multisession CD R???
By xiaofan in forum MediaReplies: 10Last Post: 11th Jun 2007, 05:12
