I'm sitting on the back of a bike, filming. The camera has some sort of built-in wind neutralizer you can switch on, but it doesn't seem to do much good here. The "swoosh-swoosh" sound that covers much of what'd be available otherwise is probably a hopeless case, what d'yall think? Giving it a try here, anyway.
that is pretty tough .... use a really good windsock next time ..
you can try sony audio noise reduction software - which is very good"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
I don't know if it will help in your case, but this is the closest thing i can see.
http://www.wrigleyvideo.com/videotutorial/tutdes_audition_noise.htm
Good luck!!!
How much wind acceptable?
By B-Twien Bytes in forum AudioReplies: 5Last Post: 1st Feb 2010, 17:44 -
removing the commentary audio track from an AVI file with mpeg layer3 audio
By wildrthanevr in forum AudioReplies: 1Last Post: 10th Mar 2009, 01:29 -
Computer Wind XP Folder question???
By rrtbusa in forum ComputerReplies: 2Last Post: 5th Nov 2008, 08:07 -
removing wind noise
By Reggie6966 in forum AudioReplies: 2Last Post: 31st Aug 2008, 11:47 -
how can i remove wind noise from a audio track
By suomiaussie in forum AudioReplies: 2Last Post: 23rd Mar 2008, 09:10
