Hello--
I often put on a DVD when I go to sleep at night. Lately its been the new Simpsons Season 5, which I noticed runs on a continuous loop instead of just freezing on the main page. Often times I fall asleep before I turn off the machine. Is this bad for the dvd player? I realize its probably not the best thing for it, but will it burn out the unit prematurely? Any thoughts appreciated, thanks!
Well, if it's playing continuously for 8 hours, sure, it will shorten the machines lifespan. You might look for a player that has an automatic shutoff or 'sleep' feature. Or is there any way to disable the continuous play feature?
Anyway if there is no way around turning it off, as long as you don't pay too much for a player, maybe the answer is, let it burn.
I have a player that has "Auto Off/Sleep" the probelm with mine is,If the DVD has a motion menu it will stay on,but if it is a still menu then it will shut off,So keep that in mind if you go to buy a new player.
I bought a plug with a timer in it. The plug cuts the power to the DVD player after a certain amount of time. It's not the best way to shut it down but it works.
Unfortunately my dvd player nor the receiver it's hooked up to has a timer on it. Looks like I'll go the "lamp" timer route, which is something I have been thinking about anyways. $7.99 for a timer sounds a lot better than $$ for a new DVD player. Thanks for the suggestions.
Anyone have a list of Sony HDD 1080P camcorders w/Night or SUper night shot
By peggypwr1 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 19th Dec 2010, 16:49 -
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 05:48 -
What's the deal w/people leaving tools bad reviews for false virus positive
By freebird73717 in forum FeedbackReplies: 4Last Post: 13th Jan 2010, 21:53 -
Dvd player locked due to bad region hack :-S
By A$$hole in forum Newbie / General discussionsReplies: 6Last Post: 12th Jan 2009, 10:17 -
Streaming from PC to DVD player but ONE big thing...
By jesman in forum DVD & Blu-ray PlayersReplies: 2Last Post: 7th Jun 2007, 14:30
