I've noticed this weird problem everytime I burn a Video DVD, the screen size seems to be very "off". A small part of the bottom and right sides of the screen were blocked off, so I was unable to see the button I had placed below in that area. I think it must be the wrong NTSC size. I mainly use 720x480. I think I might have once done a 704x480, but I think I had the same problem. My question is, what is the proper NTSC size to render a video dvd disc at on a regular TV screen?
If you are going for a 4x3 aspect. Then 720x480 is the proper resolution. sometimes I've seen 720x486, but mainly for graphics only. I could be wrong on this answer, so someone either back me up and shut me down. But for all work I do 720x480 is the right size.
Use your head, Side Step the Traps, Snake through the chaos with a SmoothNoodleMaps -
perfectchaos
Are you talking about a button on a DVD Menu? Because there is "action safe" and "title safe" areas That you must stay within. -
I know about the action-safe areas, but even the video itself is cut-off on the bottom and right sides. It's almost like the screen was slightly zoomed and panned a little by default. I'm using Vegas DVD Architect 2 on this, and I haven't used those other NTSC settings yet because I didn't want to waste any more of my DVD-Rs. I've tried it on other TVs and it was the same, and when I play it on the computer screen it fits perfectly.
720x480 is my project's ouput setting, if that's what you mean. But under the tabs "options-preferences-editing" it says "Action safe area %" set as 10 and "Title safe area %" set as 20. Do you think that might be part of the reason? Maybe if I set them to 0%, the dimensions of the screen might look normal then?
It depends on what you are viewing the DVD on. If you are using a conventional CRT, such as a DirectView television, or even some RPTVs or Front Projection sets, then your problem is overscan. Overscan essentially means the projector in your TV is making the image too big for the viewable area (hence "overscan"). Most CRT-based sets have between 5-10 percent overscan. The overscan can also be biased towards certain parts of the screen (in your case, it appears it is cutting off more of the bottom and right).
You will not notice this problem on a computer monitor, by the way.
The best way to do a menu that you are going to watch on a conventional CRT is to keep the buttons as close to the exact centre of the screen as is possible."It's getting to the point now when I'm with you, I no longer want to have something stuck in my eye..."
DVD Lab Pro, help mixing full screen and wide screen.
By stantheman1976 in forum Authoring (DVD)Replies: 4Last Post: 31st May 2009, 18:23 -
HD TV and DVD sizes
By elDuck in forum Newbie / General discussionsReplies: 2Last Post: 2nd May 2009, 09:16 -
Do I need to change AVI frame sizes before convertx to DVD
By johnharlin in forum Newbie / General discussionsReplies: 6Last Post: 18th Nov 2008, 20:58 -
dvd covers sizes
By ssaamm in forum Newbie / General discussionsReplies: 7Last Post: 14th Nov 2007, 18:59 -
DVD picture doesn't fill screen on new wide-screen TV
By ibzomie in forum Newbie / General discussionsReplies: 7Last Post: 16th Aug 2007, 04:37
