  1. Does anyone know why when I back up a particular dvd, there is a small camera icon and the text "1/2" permanently displayed on the top right corner of the playback?? I think it is related to the "angle" button on the dvd because when I press this button the "1/2" changes to "2/2". I am using clone dvd to back up my dvds. I did several of them, but this one in particular "Might Ducks" is the only one that does this with the same settings. In clonedvd, I had an option for each scene that was angle one or angle two. I unchecked all the angle twos when I did the backup, but still had the icons. Any ideas?? Thanks!! John
  2. i also have noticed that, but it never really bothered me. think it has nothing to do with clone dvd because i have used dvd shrink and nero recode and it appears with both. not like this helps but just letting you know that you are not the only one that has had that.
    How Big A Boy Are Ya?
  3. Ghoster: Thanks for that info. Was your problem also with only the Might Ducks dvd or others? The way the icon looked I thoought it was from clonedvd but apparently not. Does anyone know why we are getting this? Thanks for the reply ghoster.
  4. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    If pressing the angle button on the remote changes what it displays, then IMO it is nothing to do with the DVD itself - moreso your player. I think you need to find a way to turn off your OSD (on-screen display) on your player.
    If in doubt, Google it.
  5. i don't have mighty ducks but i have 3 others for sure that has that icon.
  6. It seams like it is something in the dvd causing it. The original does not have the icon on it at all. Also I have done consecutive DVDs and this ine is the only one with the icon. Also This icon is not related to the onscreen display. The displpay is on the other side of the screen and I can turn it off no problem.
