    Dec 2004
    Virginia
    I want to buy a divx/dvd player with support a chinese, japanese, korean subtitles.(divx)
    What model is good to me?
  2. Member jaxxboss's Avatar
    Apr 2003
    JAX, FL
    Chjako
  3. What format? If picture-based .idx/.sub then I would recommend Pioneer DV-470 or DV-575A. If you can't find try checking DV-676A seems to be the same hardware as DV-575A but I can't be sure. Philips DVP720SA also supports but you need .ifo as well.
