i just got a lite-on dvd+-r/rw 8x and i don't have a dvd-rom so i cant copy a dvd i need a guide or program that will let me make a copy without both drives also i have dvd-rw so if anyone knows a program that erases dvd-rw's in case i make a mistake i don't want to have to use a new disk thnx in advance
I presume you want to backup some of your movies? Some useful things here for you, just click on the name:
DVDinfoPRO, freeware version. It can erase DVDRWs for you. Also some other very handy functions.
DVDDecrypter, freeware. Use it to rip to harddrive and remove copy protection. For your first go, use FILE Mode.
DVDShrink, freeware. OPEN the files from last step with this. Let it shrink your DVD files (to fit a DVDR) and save as ISO. Then start DVDDecrypter again, ISO > WRITE Mode, and burn the ISO output from DVDShrink.
Almost foolproof and some feel it's the best way to do it. This should keep you occupied for awhile. Also check out the guides listed on the same page after you click on the tool.
Good luck.Pull! Bang! Darn! -
Copy it to your hard drive first, simple.
Your copy program should have an erase function.
Did you get any software with it? Try Alcohol 120%, Nero etc.
If you are copying commercial DVD's (that you own of course) then you will need something like DVDShrink to decrypt and shrink it to your hard drive.
Edit, Good tips fritzi..all freeware!"Art is making something out of nothing and selling it." - Frank Zappa -
ZippyP, thanks, it means something coming from you. I've learned a good deal from your posts, always reliable advice.
Could this be the first thread from those getting DVD burners for XMas? Baldrick really should have something prepared to put up as a sticky.Pull! Bang! Darn! -
Originally Posted by pnkrckgttrmth18
To erase a disc, use burning software. Pick one - chances are it'll do what you need.
P.S. You also seem to be a noob at writing plain English.It's very hard to answer a question in one sentence that contains more than one question.
i did what fritzi93 said and when i put it in my dvd player it said "wrong disk" does that mean i cant play burnt dvd's in it( i have a mustek if that helps)
"Wrong disc" more often means bad region info. Or in this case, that region 0, region free or all-region is rejected.
Possible to encode a Premiere Pro video in DivX format? (total noob seeks advice)
By metathran in forum EditingReplies: 24Last Post: 30th Jan 2010, 20:55 -
Total video noob, need to edit & convert videos
By HDn00b in forum Newbie / General discussionsReplies: 3Last Post: 6th Nov 2009, 00:58 -
Total noob needs help encoding from Xbox 360 footage
By FreeBaGeL in forum Newbie / General discussionsReplies: 0Last Post: 17th Feb 2008, 14:27 -
Total Noob Question - NTSC / PAL
By fredfillis in forum DVB / IPTVReplies: 15Last Post: 10th Jan 2008, 05:16 -
TOTAL NOOB... how do u use WinAVI the correct way?
By bl@h in forum Authoring (DVD)Replies: 3Last Post: 19th Jun 2007, 14:57
