I used the guide found on videohelp, however, conversion fails. I have MPEG2 file from SVCD that I would like to convert t AVI. I used VirtualDub -MPEG2. I chose full processing under video, resize filter (VDM shows the original size of 480*480, I chose to 480*320, or 360*240 or 480*480, it does not matter, nothing works) and XviD (or DivX) compression, direct streaming under audio. However, I get error messages when saving file as avi (I may provide them later, right now my computer is busy doing something else). The only option that works is fast recompress under video, however, from 800MB file it gives me the target size of 46GB. Since I do not have so much free space I have no choice but to abort the operation. What am I doing wrong?
Foxconn A79A-S|AMD Phenom 9950 BE|8GB RAM|150GB WD Velociraptor|2 HD4850 in Crossfire|Windows Vista 64 Ultimate SP1
Abit NF7-S|AMD Barton 2500|1GB RAM|3*160GB HD|HD3850|Windows XP Pro SP3 -
You're not posting what we need to know. Get back to us when your computer lets you and give us the error messages. The gurus are knowlegeable, but not clairvoyant, except for Cobra, but that's another story. See you then.
Hello. -
Sounds like you haven't chosen your AVI Codec to convert to - It's Under VIDEO-->Compression in VirtualDub. Choose Xvid. If you don't have that as a choice, install it.
AVI to MPEG2 Conversion Software
By cyberboy in forum Video ConversionReplies: 3Last Post: 7th May 2009, 20:54 -
DV-AVI conversion to mpeg2 or DVD
By obadvw in forum Video ConversionReplies: 6Last Post: 17th Apr 2009, 06:59 -
AVI to Mpeg2 conversion
By carlmart in forum Video ConversionReplies: 122Last Post: 13th Mar 2009, 06:04 -
MPEG2 to AVI conversion.
By fl3tty in forum Video ConversionReplies: 5Last Post: 4th Dec 2007, 00:31 -
AVI to MPEG2 conversion
By Alexstarfire in forum Video ConversionReplies: 8Last Post: 6th Aug 2007, 18:42
