i want to save my music vhs collection from the last 20 years and transfer it to dvd. therefore i built in an adaptec videoh! PCI card and installed the bundeled my dvd software. everytime i try to capture more than one video to compile on one new dvd i do not get a proper dvd structure i.e. no VOB files, but mpeg2. has anyone an idea what i do wrong or which software to use for that purpose? thank you for your answers!
merry christmas and a happy new year!
Hi
You must author the MPEG2 to DVD, Take alook here...
www.videohelp.com/author -
Thank you for the fast reply, but there are two problems with that: 1. when i follow the link there is no mpeg2 to dvd and the mpg to dvd does not work
2. when i do that with more than one mpeg i have to build a dvd structure again and that was what i wanted t do with the my dvd programm in the first place ... -
You alrady have a MPEG2 , You must author the MPEG2 to a DVD structure..I'm not sure i understand what you are asking.
I'm assuming you have a file named something like "MyVCRTransfer.mpg"
The absolute easiest way - Download the free VSO Software DivxToDVD application and run your mpeg file through it. The app will accept the mpeg file and leave you with the .VOB, .IFO, and .BUP files you'll need. I know this involves encoding again, but it ensures your files will be DVD compliant. It's unlikely you'll notice any difference, considering your source.
http://www.vso-software.fr/download.htm -
Personally I would recommend using GUI for DVD Author for converting your mpeg 2s to dvd structure (vob, ifo). Its a great freeware program that lets you keep the menus as simple or complex as you want.
You need to use an authoring program on your MPEG-2 file(s). Most decent authorers (GUI for dvdauthor, dvdauthorgui, TMPGEnc DVD Author, DVD-lab) will be able to handle multiple files.
If in doubt, Google it.
DVD Lab Runtime error c++ compile.aux?
By dcook in forum Authoring (DVD)Replies: 10Last Post: 29th Aug 2010, 21:46 -
Using Magix Photo Story CD/DVD 8 to compile photos
By Surber in forum Newbie / General discussionsReplies: 1Last Post: 24th Jan 2010, 19:08 -
Compile VCD movies plus subtitle into one DVD
By GeekyChocolate in forum Newbie / General discussionsReplies: 5Last Post: 26th Feb 2009, 07:14 -
Noob here, Compile Dvd problem!
By dbgt in forum Authoring (DVD)Replies: 3Last Post: 8th May 2008, 18:08 -
DVD-lab pro compile problem
By Sats in forum Authoring (DVD)Replies: 8Last Post: 11th Sep 2007, 15:13
