Hi,
I have a Toshiba RD-XS32 HD/DVD-RAM recorder. I record HBO programs on DVD-RAM since HBO has the "record once" restriction and only records to DVD-RAM. I had hoped to then transfer to my PC and then burn back to a DVD-R. However, I have just had the same problem with a couple of recordings. It plays fine on the original DVD-RAM in the Toshiba, but playing the DVD-RAM in my PC drive (or copying from it to the HD) doesn't work. It starts playing then freezes (weird color blocks, etc.) after about a minute and a half. If burned to a DVD-R it does this in the Toshiba too.
Any ideas on why this is happening? Is there a problem with the DVD-RAM maybe, need to do physical format on it? I think I'll try that. Hopefully I can get around this.
Thanks.
Results 1 to 1 of 1
Problems ripping multiple VRO titles from Samsung created DVD-RW
By brancusi in forum DVD RippingReplies: 5Last Post: 8th Mar 2012, 13:19 -
Using Videofiles created by Toshiba Gigashot with Adobe Premiere
By ACvanRijn in forum Video ConversionReplies: 4Last Post: 22nd Nov 2010, 07:42 -
VRO Files
By bz186 in forum SVCD2DVD & VOB2MPGReplies: 11Last Post: 3rd May 2010, 11:11 -
Extracting .VRO files???
By jbrdbr111x in forum Video ConversionReplies: 12Last Post: 24th Jun 2009, 21:34 -
VRO files
By tvlreject in forum Newbie / General discussionsReplies: 14Last Post: 8th May 2007, 14:31
