  1. I can't figure out how to delete all the navigation links (from chapter selection to chapter selection) on DVD-Lab Pro menus. Unchecking "Auto-route" only seems to remove some links.
    I've searched the help files and the forum, but didn't come up with anything.
    Aug 2001
    Netherlands
    easiest way would be to select every link one by one with your right mousebutton and click 'remove link' in the popup menu.
  3. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    The easiest way is to turn off auto-route and re-route manually. This will replace the existing routing with your new routing. I don't know of a simple way to clear all the routing.
    Read my blog here.
  4. Thanks for the advice.
    I ended up removing all the button links individually, then making sure I had Auto-route unchecked, adding all the button links again, then doing all the routing links manually.
    I just have to remember from now on to uncheck Auto-route before I start adding links to any buttons.
  5. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Turn off auto-route before adding buttons, as it builds the routes as soon as the first button is created.
    Read my blog here.
