Help,
I am attempting to burn a bunch of beatles mpeg video files using nero 5.5. I followed the "How to make a VCD with Nero 5.5" guide on the vcd website, but must be doing something wrong. About half of the files I dragged had to be converted by Nero, but that seemed to go smoothly. When I do the final step (burning), Nero simply stops. I printed out the message file, but hell if I know what it means. Any advise would be great.
If you want to make life easier for yourself , in the long term, get yourself a downloaded version of Virtual Dub, Tmpenc and VCD Easy. These 3 tools will be a godsend and you will learn tons of stuff. VCD easy gives you a choice of making a VCD or SVCD. You can convert your Mpeg files using Tmpgenc. I made a costly mistake and bought the MPEG encoder from Nero and it is crap! and my VCD's and SVCD's wont fast frwd or Rwnd on a philips DVD player. Virtual Dub is great for capturing files and TV Pics. VCD easy is simply brilliant at making VCD's , it inserts chapters and entry points into your files and it will also perform a "dummy" run and warns you what the problems are and so must outclass Nero in this field, because they actually work on my DVD.
Problems burning AVCHD w/Nero & IMGBurn...
By girlcreeture in forum Authoring (Blu-ray)Replies: 7Last Post: 3rd Sep 2011, 10:31 -
problems burning with nero and imgburn-pixlation and long burn
By pokitisme in forum Software PlayingReplies: 5Last Post: 2nd Sep 2009, 02:12 -
Problems Burning Discs with DVDshrink/Nero
By iownju in forum DVD RippingReplies: 5Last Post: 20th Jul 2008, 15:56 -
USING Nero TO SOLVE ALL BURNING PROBLEMS?
By guitarparth in forum Newbie / General discussionsReplies: 8Last Post: 16th Nov 2007, 18:18 -
burning problems with nero 6
By jjob222 in forum Newbie / General discussionsReplies: 6Last Post: 16th Jun 2007, 15:36
