What I'm looking for is a way to backup encrypted DVDs using two drives. The first to read (DVD-ROM) and the second to write (DVD-R), hopefully at the same time.
I understand that there are compression issues and I will need to compress the full disk down to a DVD-R size, and I hope to use DVDShrink for this, because I've used this at work a few times and like it. But that was only for reading THEN writing. But at the same time I'm willing to spend a few bucks to buy a program that makes this easier.
So if anyone knows a way to cut down on copying time by writing at the same time as reading (and decrypting), please let me know.
Thanks.![]()
On the fly is rarely encouraged.
It is better to rip the dvd to the hard drive first then burn. -
I've tried this what you get is crappy dvds. What I finally did was to invest in a faster burner Pioneer108 and use the fastest dvd+ on the market. It cut down the burning time big time.
Thanks....
Just providing the "on-the-fly" search term was enough to get me going in the right direction on this topic looking at other forums. That and if I try it I'll make sure I've got my drives on seperate IDE cables.
DVD-ROM Backup
By 329329 in forum Authoring (DVD)Replies: 2Last Post: 11th Mar 2010, 12:24 -
How To Backup a DVD-Rom On a Blank DVD disc
By tealmarlin in forum Software PlayingReplies: 3Last Post: 8th Oct 2009, 12:13 -
Replace dvd drive with dvd-rom drive.
By jtrapat1 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 25th Dec 2008, 10:33 -
Help on Choosing a DVD-Rom Drive
By scustalow in forum DVD RippingReplies: 1Last Post: 13th Jun 2007, 11:04 -
hd-dvd rom drive
By computerchuck in forum Software PlayingReplies: 6Last Post: 8th May 2007, 07:55
