Hey,
I bought a dvd recorder yesterday, a Philips 610.
I can't get it working![]()
Im trying to connect it to work with telewest cable...
How do I do this? I have tryed so many different ways, and I have only managed to get a crap quality picture?
Please reply asap, I really want to get this working.
Thanks in advance...
Results 1 to 20 of 20
How many ways can there be? What equipment do you have besides the recorder and tv?
I have only the tv, and dvd recorder...
I have tryed loads of different ways of doing it
Only managed to get a bad quality picture some ways...
I want it to connect to my telewest cable box so I can record of it, and hopefully use video+ as well -
Is your cable box digital? Did you have the box hooked up to a vcr? What is video+?
Yes, it is digital.
I didn't have the box hooked up to a vcr...
and video+ is where you can type in a number from tv magazines, and it starts recording when the program comes on -
Are you using a coax cable? When using a digital box the dvd recorder can't act as a tuner.
I have tryed coax cable and scart cables etc, been trying lots of different ways, still no luck
By no luck, I meen...the best I am getting is a fuzzy picture -
Digital cable box -> DVD recorder -> TV set
Lordsmurf, I have tryed that...
Can someone please tell me exactly which cables and where to put them?
I will try exactly what they say...and let them know what happens.
Please include where to put coaxs, scarts, and into what slots. Thanks -
Have you tried using the manual?
We don't have scart in my part of the world. When using coax you have to make sure that the sending and receiving channels match. At least that's what I recall as I haven't used it in a long time. -
Seriously, ive been through the manual, and internet sites for hours trying to get this thing to work....and still not got anywhere.
I think a fuzzy picture indicates that the channel is et right. Try setting the recorder to channel 3 or 4.
What do you meen by change channel? I've never changed the channel before, because it only finds one..which is the telewest cable.
First off, I'm referring to coax, since I know nothing about scart. The remote for the recorder should have a way to select which of the inputs you want to use. Set that to the coax input. Then use the channel up/down (or +/-) buttons to tune the record to receive on channel 3 or 4. This is what's commonly used in N America.
I can't see an option to choose coax on my remote.
So, even though it only finds one channel? Ill try and change it to channel 3? -
It's been at least ten years since I used coax connections or had cable. I better leave this to someone who is familiar with your setup.
sync!!!!
Thanks man!!!
I changed the channel, and it was perfect picture!!
Im going to have a little fun with it now
No Media Present on my DVD
By thekaptn in forum DVD RippingReplies: 2Last Post: 14th Oct 2009, 09:24 -
Do you keep your xmas gifts?
By Xylob the Destroyer in forum Off topicReplies: 12Last Post: 7th Jan 2009, 01:56 -
What'd you get for XMas?
By Xylob the Destroyer in forum Off topicReplies: 0Last Post: 26th Dec 2007, 17:53 -
xmas gifts?
By pantsonfire in forum Off topicReplies: 11Last Post: 20th Dec 2007, 12:04 -
VIDEOHELP 2007 Official Xmas Choreography ***Merry Xmas***
By MeDiCo_BrUjO in forum Off topicReplies: 0Last Post: 15th Dec 2007, 15:02
