I was wondering what produces better results when converting 23.976 fps source: 3:2 pulldown or 23.976-25?
I live in PAL world but I really donīt care because my dvd player + projector can read both formats so... Iīm asking about quality.
J
Try vso divx to dvd,Ihave great result with it,and easy to use.You will find it on doom9 or cnet
23.976-> 25fps
only reason though is because it is pal ... not because of the frame rate .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
he asked about divx to dvd ... dvd copy not going to help much ..
I would keep it at 23.976 fps with 3:2 pulldown cause if you convert to 25fps you have to speed up the audio by 4% and it might sound a bit fast for you.
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 10:11 -
unable to play hd divx on HD 1080p divx dvd player
By underscore04 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Jun 2010, 14:00 -
Best Divx Ultra DVD Player with Full file Names for MP3 and DivX Files
By MCalca1706 in forum DVD & Blu-ray PlayersReplies: 11Last Post: 12th Nov 2008, 13:00 -
Converting HD (DivX/MOV/WMV etc) to DVD or DivX ???
By snadge in forum Video ConversionReplies: 32Last Post: 8th Jan 2008, 06:48 -
Will DIVX with Menu Play on Standalone DVD-Divx player?
By psxiso in forum Video ConversionReplies: 5Last Post: 4th Oct 2007, 11:24
